I wanted to find a Hunter Case movement so that I could use the original dial and not have to get it refinished to match the new layout of a wristwatch conversion. I was lucky enough to find this Hunter case E. Howard 12s movement with a pristine dial. Amazing that the movement, dial and hands are all over 100 years old! The movement also has a "Safety Barrel" meaning that if the mainspring ever breaks, it will not damage the train wheels with the sudden recoil of the spring barrel. Case is 46mm without the crown, but really does not feel that large on the wrist.
Edited by DJW
Nice - Howard made good movements - and yours is in fine fettle!
Thanks Will!
I try and build stuff that I like, but will be appreciated by others as well. And, There is just something about these vintage movements that I find intoxicating!
That is a nice watch, do you ware it everyday or for occasions?  Or would you sell it on?  (difficult to sell on if you put love and time into it).
I actually build these to sell...which I just sold this one today!
Well done Don. :D
    • The ones I have opened also do not have a pry point , hence the reason for the tool. The watch is clamped in the tool and a blade is screwed into the seam, the blade being chamfered lifts the back then the screw shaft is turned and the back comes off have a look on Ali express for case back removal tools
    • I don't think I need to know more about the question now, so please don't write anything related to the topic. Thank you to everyone who wrote. Have a nice day.
    • It's an exhibition back so no access as you suggest.
    • I have no experience with this watch, but looking at the pictures from the ebay listing linked above, it looks like the outer metal bezel at the back of the watch may not be part of the case proper.  It looks like the watch and strap are sandwiched together, and an inner case may push out of the rear bezel towards the front of the watch.  A case style similar to the Roamer watches where the crystal, movement and caseback pushed out through the back of an outer bezel, only in reverse - this one may push out towards the front.  To test this, you would need to hold the watch, dial down, supporting the dial side of the watch around the edge of the bezel without touching the bezel itself. Then push down carefully on the inner metal ring you can see at the back of the watch. I’m speculating here, proceed at your own risk. Hopefully someone with hands on experience of these watches can chime in! Best Regards, Mark
    • Thanks, Mark. That's the kind of reassurance many of us wanted to hear! Yes, life is unfortunately unpredictable, and it would be a shame if the many dedicated WRT: ers became stranded if, god forbid, something happened to you and WRT stopped working.
