Identification please
transporter
Hi guys, can anyone identify the maker etc of this clock from this picture please
{option}http://i1302.photobucket.com/albums/ag132/Pjw24771232/76B5F72F-F932-412B-BE65-C1CBBECFAC8C_zpskzvs775l.jpg[/IMG]
also, this is the balance wheel, now the staff is broken as can be seen, but I'm stuck on how this balance works. It doesn't have an impulse pin/Jewel on it, has it disappeared or is it meant to be part of the staff which has broken?
{option}http://i1302.photobucket.com/albums/ag132/Pjw24771232/AB765537-7737-40FC-92E1-2D16C647BF35_zpsu8pcsca3.jpg[/IMG]
heres the escape wheel if this helps you to explain this problem to me. First time on a movement like this, it's pretty clean apart from the broken balance.
thanks in advance
1 hour ago, transporter said:
Am I right in thinking that the balance staff is a cylinder it a cut out in it which allows the escape wheel to enter and thus turn then exit and so forth?
Quite right it is a cylinder a broken one. and it wouldn't have an impulse pin or pallets. I'll be very basic here it worked by direct drive, from the m/spring through the train (wheels) to the escape wheel and into the cylinder balance.
Many thanks for the reply and confirming my thoughts on the balance staff, s for the other picture, well that is a picture of the clock movement, the click is the click on the clock movement (below the key and then the balance) I included that in the frame as it has "france" stamped into the plate next to the click, below that on the other plate is the only other mark on the movement, it looks like a thick "J "  and the number 66 next to it, im hoping this will identify the movement enabling me to find and replace the balance the staff.
Hope this makes sense to you now mate.
So it has a platform with a cylinder escapement. You might be able to get a complete replacement from ebay, you need to measure the platform width and length and the depth of the escape wheel so it engages with the contrite wheel (that's the wheel that has its teeth at a funny angle). I don't expect the screw holes to be in the right place on the platform but you never know.
Hi oldhippy, ok im good to measure the width and depth of the platform, I think, is the platform the rectangular plate that the balance cock is screwed onto?
Now, the contrite wheel ( funny angle teeth ) I would call that the escape wheel ( watch background ) this is where I'm slightly confused with your description, I apologise sorry. What wheel is the escape wheel, once I get to grips with that I might be able to work out how you  ant the depth measured.
Sorry to be a pain with my confusion on a subject that I know you are well versed in.
Is the platform the rectangular plate that the balance cock is screwed onto?
Yes that's correct. Here is a photo of a contrite wheel a very worn one that I got from google images. The escape wheel is the wheel that is fitted into the platform between the cylinder and the contrite wheel.
Ok finally made it home, the movement doesn't have a contrite wheel the escape wheel directly drives the next wheel in the train
{option}http://i1302.photobucket.com/albums/ag132/Pjw24771232/EF809AA2-D13B-4751-9684-072CF7AE370B_zpswndmtzrs.jpg[/IMG]
{option}http://i1302.photobucket.com/albums/ag132/Pjw24771232/4127197C-C59C-43E0-AEEC-7717837B4D77_zpsimc1hdeg.jpg[/IMG]
as you can see from the photos it's quite a simple movement but still I have no idea of the maker etc, or how to find a replacement balance staff
I've had a look at your photos and you are correct.
It doesn't require a balance staff but a cylinder. These are very very hard to make and can only be undertaken by a specialist, the cylinder is made up of three parts two ends which are called plugs and the center part all are very brittle. to have this work carried out would be very expensive, the cheapest way would be find a second hand one on ebay, but be careful, you don't want one that is to worn as it wont work or keep good time. The only other way you could go but this would also be very costly have a new platform fitted which would have a lever escapement, but it will de-value the clock, to be fair to you the clock doesn't have a high value.  If there is no makers insignia on the movement it will be impossible to find out.
The only marks on the movement are of a large J shape followed by 66. I have seen a number of cylinders for sale on the bay, im thinking of measuring mine to the best I can and seeing if I can find one the same ( fingers crossed). I done some research on the cylinders and how they are made etc, very interesting stuff and beyond my means without the correct tooling. So the hunt begins!!!!
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
