Battery Change On A Tag Heuer Diver's Watch
Similar Content
The number in the case (1444) is the reference number. On older movements it's a shorter number. When I applied I sent the serial number from the movement and the reference number on the case back. In my case for a 1967 Cal 30L the case number was 7855.
Hello! Finally got a 7750 to work on, all has gone without a hitch, and now about to do the one bit I'm not really looking forward to, fitting the hands. I have a 7750 holder with screw-in inserts to support the jewels, the minute register jewel seems well supported, but none of the inserts fit inside the automatic plate hole for the centre jewel. Pictured below jewel with the holder insert. Could someone confirm how I'm supposed to support it please? Thank you!
