Is there any punches where one can put a very small punch or drill on? Tried to remove some old pivot from a second hand. From the other side? Would have been awesome to have a punch that was 0,17 in diameter or smaller. I did manage to remove it with a tweezers edge and cleaned it with a small nylon strip from the toothbrush. But next time?
    • Hi watchweasol, yes that is a way of doing it I suppose, I have a pair of mainspring hole making pliers on their way off eBay, the ones with the different shaped punches. I may be able to use them to make a hook.
    • Hello everyone, Glad to be here.
    • No mate. Sorry if that offends you! Also please don’t take threads off-topic. I thank you sir.
