Chinese Timegraphers
The  Chinese have a interesting sense a humor for marketing Various spellings of Witschi Which can be found at the site below. Very very nice timing machines unfortunately rather expensive.
http://www.witschi.com/en/home.html
Another option for timing machine because it's in a very similar price range is the 1900. Both the 1000 1900 Are functionally very similar except 1900 has some added features and  a much nicer display with smaller pixels. Then because it's color display there are some other modes because they can change the color display. One of the more useful things is the display mode where you see 96 seconds and still another mode which will display 192 seconds.
  • 2 months later...
hi guys, i have just leapt into the 21st century and invested? in a timegrapher 1900 haven't got it out the box yet but read the instructions which took all of 5 minutes what a let down i was expecting at least some screen shots of faults or what to look for so what i need is some advice or is there some docs somewhere to download, thanks lads
hi guys, having used my timegrapher for the last two weeks and wondering before if it was worth getting i now wonder how i managed with out one, but now i have a little question, i have a movement on it that that does what it should for about a couple of seconds then goes to the home screen and then back again to the evaluating screen and so on, the movement is working fine thro this and the machine is fine with another movement, just wondered if anyone else has had this prob, thanks, steve
  • 2 months later...
Hello Folks,
Good news - I took delivery of a "2015 New Coaxial LCD MTG Watch Tester Timing Multifunction Timegrapher NO.1900" yesterday - Birthday present from my gorgeous wife. :woohoo-jumping-smiley-emoticon:
Bad News - I did have to pay duty (£20.00) to DHL prior to delivery :thumbsd:
Worse News - It was immediately confiscated by said wife and I am not allowed to even look at it until my birthday  :startle:
Oh well just have to survive until then :beerhat:
Cheers,
Vic
Hello Folks,
Cheers,
Vic
Lucky guy Vic. I wish my wife gave me presents like that[emoji1]
Sent from my GT-I9505 using Tapatalk
I have been using a 1900 since March last year (curiously enough also a birthday present from my lovely wifey) and have to say that it is quite a good machine for the money. I think you would have to spend a heck of a lot more to get any kind of a meaningful upgrade on it.
Hello Marc,
Thats good to hear.
I did the research that I could looking at the opinions and have to say that you have come up with the same opinion as me.  At first I was looking at the 1000 but for the difference in price it seemed worth it.  It seems to be a good balance between cost and efficacy.  And of course there were some resounding recommendations from other forum members like old George ;) .
Cheers,
Vic
  • 8 months later...
I am thinking about buying a timegrapher.  I have seen some on Alibaba for about $150 including shipping costs.  Has anyone here tried one of these?  They are made by Wei Shi and are offered in 120  or 110 watt models.  The model I have looked at is the #1000.  Comments, praise, and criticism are welcomed.  Help me make a decision.
very useful, they work great and save lots of time/aggro.
I have the 1900.  differences to the 1000 are color screen so the tick and tock are different colors and the pixels are smaller than the 1000; graphing display can be changed to show longer time ranges and has a couple different curves; resolution is .1 instead of 1.0 for some measurements: lift angle and fast/slow and the 1900 does "signal conditioning" or some other unknown mumbo jumbo.
i don't know if any of those are worth the price premium (other than the color screen) but I got it for the same price as the 1000, so it was kind of a no-brainer for me.
btw, the sound it makes is not the actual sound of the watch - it's generated by the tester.  which is kinda lame, imo.
Edited by Hertzogpholian
http://watchguy.co.uk/improvements/
3 hours ago, maclerche said:
For 15x the money of the Chinese one, you get a bigger display (that is harder to read), and it shows exactly the same beat rate, amplitude, etc. as the Chinese one. Down to the last s/d. But you can do Omega co-axial escapements on it, so there is some advantage. And I can call myself serious now
Christian at his best. Always straight and down to earth. Try asking some other "watchmaker" about their $5,000 timing machine sporting  a lo-res display straight back from the 80s, they will tell you that it's unique, inimitable, and worth more than what it cost.
  • Similar Content
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
