Thought it would make nice little project, changing the seals and such like if it's not working, I would think there won't be much to it inside and with it all being mechanical rather than electric it should be easy to get my head around sorting it out.
I might even try and rig it upto an electric compressor  to get a vacuum working off a switch. Not sure what would be involved in doing that until I have a good look at but if nothing else it gives me a shell to work on.
The Rolex 1050 vacuum wet test I use at work goes to the same -.9 bar this one is rated to and the Rolex ones are over £4000 on eBay.
1 hour ago, Geo said:
£3800 of that is for the name!
Your probably not wrong there!
Seriously though, I have struggled to find a wet vacuum tester for a while, plenty of cheap pressure testers around for the £200 mark but they only go upto 6 bar which is no good for 100m watches. From experience a wet vacuum test to -0.9 barwill nearly always show where the leak is after a watch has failed in the dry tester at either 10 bar pressure or -0.9 vacuum, so given the choice for one machine at home the wet vacuum test should be an accurate test and will also show where it is leaking, presuming I can get this old machine working properly.
If it is knackered I could always remove the omega badge and paint a Rolex badge on it and stick it back on eBay half price at £2000!!
    • Hi watchweasol, yes that is a way of doing it I suppose, I have a pair of mainspring hole making pliers on their way off eBay, the ones with the different shaped punches. I may be able to use them to make a hook.
    • Hello everyone, Glad to be here.
    • No mate. Sorry if that offends you! Also please don’t take threads off-topic. I thank you sir.
