While tackling around in the Roskopf balance i noticed that the pin pallet lever is far from being balanced. Had no problem like this in smaller watches but reading a bit in watchmaking books it seems that this part need a good poise. What do You thin? Shall i file down from the fork end and/or add more weight on the other end?
I would leave it as it is.  It has obviously been specifically designed that way with a specific mass of metal deliberately distributed and shaped.
If you were to remove metal, you will probably speed up the escapement and take it out of the range that the regulator is capable of compensating for.
I did not know a pin pallet had to be poised. I don,t know if it is the angle of the final picture but the pins look different widths if so that is wrong.
Well, just imagine both the lever rotation axis and the lever itself are in horizontal position (e.g the watch is in my pocket). There is different push on the balance in the two directions from the fork. Bigger downwards and lower upwards (if the fork end is heavier). Measured that before stripping down the movement, it even stopped sometimes on the position mentioned. There was no problem (not that big difference in rate and amplitude) if the rotation axis or the pallet (or both) were vertical. There must be some weight balance!
It has to be mentioned, at that time it has a wobbling balance caused by the untrue balance wheel and the worn balance bushings. But if this would be the problem source then it would have stopped if the pallet fork is vertical and the balance axis is horizontal.
I can change the balance spring length, since it is fixed by a pin. Rate adjustment (or shaping the spring if needed) should be no problem.
I didnt noticed that the pins have different thickness. Will replace the thinner.
Meanwhile, i have found a nice procedure for pin pallet escapement service:
https://www.dropbox.com/sh/gukk9my456xi2gt/AAAqpVVbth5uxnTJ_T60YIV5a?dl=0
the  internet is strange compared  to a book.  the  definition of "rail road watch"  can be challenged.      vinn
    • That’s a nice idea, But i’m committed to providing this site as a gift to the watch repair community as my thank you for my incredible life i’ve had in this business. Ive done well and unless my financial circumstances change then i’m more than happy to foot the bill. If circumstances do change then be assured that I will make an appeal. For now, I’m comfortable with the way things are and I am extremely delighted to remove Google Ads from this site and to stop Patreon, it feels like a major step forward 🙂 Sorry, I missed your reply, I got blinded by another poster in this thread. Yes - I can confirm that I have always seen WRT as a not-for-profit website, and therefore - not a business as such. I’m lucky and have done well in my life due to a decision made in my teens to start a watch repairing apprenticeship which has sustained myself and my family for many years now. Consider this my small way of paying it forward. Ive been committed to keeping the site alive on a technical and financial level for over 10 years now and I have zero plans to change that. Thank you for your kind words by the way. And as for your wish - nobody can control what happens in life, if something happens to me I have things in place with my family but I’m just not comfortable talking about my personal business - I wish a certain person would respect that, but i’ve calmed down now - i’m only human 😄
    • Yes, exactly. I've seen a few different versions, but mine has the blue water symbol, not white.    I think it's Acrylic. The case is plastic so I would the is the lens would be too.
    • Hi there Josh, welcome to the forum.
    • From the same listing, the back side: I would guess that the back pops off rather than the front. You can see a little groove there where the caseback sits over the winding stem, rather than a case tube. Look for an indent or notch around the back. It might be possible to pry this off from almost anywhere on the back if it sits right against the rubber strap. The movement looks like it is from the Ronda RL family (015 or 115 or something? I forget which numbers have a calendar and which don't)
    • I'd expect a similar notch somewhere around the rear to pop that off.
