My next watch on the table is an old Anker Ladies watch that my mother in law gave me. She wanted to throw it away anyway since it is not running anymore.
The first thing I found out is that it is the caliber 57/4 built by Uhren-Werk Ersingen (UWERSI) I wasn't able to date the movement. Maybe somewhere in the late 1950's or 1960's.
Situation:
  • Fully wound, does not start.
  • Slightly rusty
  • overall condition: requires cleaning and service
The first thing I did, after removing the dial was removing the balance wheel and cock. I saw immediately that this will be a challenge for me! In order to clean the stone, I need to remove the hairspring. I wonder it I can to that with my skills. I dipped the entire assembly in Bergeon One-Dip. But I guess this is not sufficient.
Your advice is highly appreciated.
Cheers Alexander
Sorry, folks. This will come to an abrupt end here. I was barely able to remove the screw of the pallet fork bridge. Then I was totally unable to unscrew any (!) of the screws of the dial side. It is also impossible to remove the hairspring since the screw in the stud is highly rusted.
I stop here since I have quite a couple of movements to work on.
However, you may come up with ideas of how to remove screws that are stuck from corrosion. I just put everything in a box. Maybe I can come back that later.
Cheers Alexander
Hi Alexander,
This is the stuff I use:
slf.jpg You need to put a few drops in and leave for a few minutes for it to work.
Also, sometimes leaving parts in some oil 3-in-1 or -- I've heard -- motor oil (not too sure about this one) may work. Some people even use CocaCola in some rusty parts...I go with the picture above...it is safe for the hairspring.
There is also Bergeon 30496 for rust but it can be really tough on delicate parts if left for too long.
Cheers,
Bob
Thank you Bob,
I was looking for something like that, but I can't find it. Do you have a brand name? I looked on ebay, CousinsUK, Amazon to no avail. What I have is WD-40. Will this work?
Cheers Alexander
NO! No, WD-40! It would damage the watch like for life...It sticks and makes quite a mess. This one I posted comes exactly like that. On the other side it says: Optical Supply Inc., Western. Product #4110. Nothing saying what it contains...so if you are able to find out let us know.
Cheers,
Bob
Thank you Bob,
I did some more research, to no avail. Seem that this product is not available in Germany.
Maybe I go for the Bergeon product.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
