clockboy & Vic,
I'll disassemble soon.  I just need to find a couple of free and alert hours...and the confidence.  ;)
I'll keep you posted.
Vic,
was there anything different or "non-standard" about re-installing the hands?
Thanks again for the counsel and encouragement.  I appreciate it.
Doug
As I remember there was nothing special about the hands.  Just the usual stuff, ensure they are located firmly keep them parallel / not touching, locate hour and minute both exactly on 12 (nothing worse than the hour hand not being dead on at 12 noon) the second hand usually located exactly on a chapter marking as well.  I use the bergeon dial protectors but paper or plastic is ok.  Some watches need a bit support to the other end of the cannon pinion but as I recall the Tissot was ok.
Cheers Vic
Hey all,
I finally mustered the courage, got off my ever-burgeoning backside and worked on this today. I took the dial side apart but didn't see anything obviously amiss. So, I reassembled and the stem inserted completely. It's running and setting correctly now. Go figure.
Thank you for your very friendly advice and encouragement. I appreciate it.
Best regards,
Doug
hello Doug,
It happens sometimes that things just come together despite a long period of trepidation.  In the North East we have an expression "S**t or Bust" which generally means what will be will be so just get on with it and in this case you have come up trumps so bask in the success.
Cheers,
Vic
  • 6 months later...
Hello Duhgluss,
When I saw you had unscrewed it 3 turns my heart sank as, just like George, I agree with our Bob and Clockboy.
There is always a chance we are wrong but basically parts will probably have dropped out of position on the dial side and are fouling the pathway for the stem and you can't resolve without dial removal.
You will need to take off the hands after protecting the dial with a thin bit of plastic or paper cut to fit under the hands on top of the dial which means you would need the tools to release the dial (normally held on by two screws that hold on to two prongs on the dial back), Presto hand puller or the like and presser to put them back on plus appropriately sized screwdrivers (not too big or small). You will get everything but the screwdriver for about £6.00 if you get the cheaper Indian or Chinese makes.
There is a load of stuff on the tube about the process involved and our Mark has covered it in general on some of his videos.
This was the second watch I ever worked on and it was quite easy so its up to you but I would give it a try, just make sure to take pics every time before and after you remove something.
Here is some info that may help.
attachicon.gif4256_Tissot 2031,2037.pdf
attachicon.gifTissot 2031 Manual.pdf
Cheers,
Vic
Thanks Vich. I am actually working one right now .So perfect finding the manual and PDF. Having some trouble with the date wheel . It's a little bent . Manage to straighten with a homemade punch .I  don't now if it would work until i have rebuild the movement again.
Edited by rogart63
And i think i will have to take everything of again :mellow:  And clean the oil of? As it should not be lubricated . Only the time setting mechanism . The wheel that is bent is the 450/1
Hello Rogart,
Some time ago I bought the Bergeon Quartz oil but in fact have hardly ever used it.  Hope the wheel is flat enough.Good luck with the rebuild.
Cheers,
Vic
I put it together and so far it's working. In the manual it say just oil the time setting post for the 450/1 wheel with 8200. And the lower bearing in the mainplate with 9010.  Nothing else.
  • 1 year later...
Hi all -- this thread helped me avoid a major foo-pah!   I got the stem out without issue thanks to you all!
BUT....my movement seems to be "stuck" in the case.  I removed what appear to be two case screws and the stem of course.
Shouldn't the movement just fall out of the case at this point?
and BTW....seem to have lost a case screw ... any idea of the best replacement source?
Maybe the movement has to come out the dial side . Is it a square case you have . Cousisnuk may have the case screws.
Edited by rogart63
Hi PWR
Most of us end up with a pile of scrap watch parts that yield screws and other parts. Most of the screw selections on eBay are not watch type but occasionally you'll find a pack of watch screws.
By the way it's faux pas - French for false step.
Cheers Neil
  • 6 months later...
sorry to dig up this old thread, but...
I have a PR516 divers watch with the 2031 movement.  I undid the stem screw by two turns
Nothing
an extra half turn for luck
Nothing
Sweating now, I made it a full three turns and the stem slid out.  I nipped the screw in while I await my new crystal (2.7mm thick! )
:woohoo-jumping-smiley-emoticon:
Thanks for the previous answers that helped
  • 2 years later...
As always, the advice on this site allowed me to successfully remove my stem from Tissot 2013
BUT....after removing the single case screw I saw...I cannot figure out what I'm missing to remove the movement from the case
It also appears, I might be wrong, that the bezel is removable....but not easily.
Appreciate any advice
Why hooking into an existing thread since this is a new question?
BUT....after removing the single case screw I saw...I cannot figure out what I'm missing to remove the movement from the case. It also appears, I might be wrong, that the bezel is removable....but not easily.
You should post pictures top and side.
This movement doesn't have case screws. The movement is typically held in place by friction.  Try removing the movement spacer/ring. Best wishes for success, Doug
  • Similar Content
    • Hello and welcome from Leeds, England . No idea about Citizen but someone will advise soon.
    • Hi Chris and welcome to the forum, The hands and knees is by way of the rite of passage, we have all done that at some time or another.   Added a bit of citizen gen plus the T Z glossary Citizen Technical Information.pdf TZIllustratedGlossary.pdf
    • By the way, I opened my watch, looked under a magnifying glass, there is simply no grease, the screws are without traces, the slots are intact.I think it's just a matter of maintenance.there are no rotor marks on the body. And to remove the strap from yours, just press on the 1st side,and slightly move the strap, then on the other side and it will come off.
    • Hi My name is Chris. Just started trying to learn about watch and clock repair as a result of repairing my fathers old 1890s police station clock (about a year ago). The clock was Ok, but having graduated to pocket watches and then wrist watches, despite the really excellent stuff on Youtube, I am struggling a bit.  As a retired engineer, I find the engineering exquisite, but a bit on the fiddly side.  I have done a few practice watches with a little success but failed a few, but have had success with Seiko 7005s, 7009s etc, but have just attempted a citizen 5430.  Nightmare.  My wife thought I had found religion as I spent so much time on my knees with my eyes to the floor looking for springs.  Got through that and found that the balance is shot.  Trying to source one or something that will fit from the citizen range has me totally perplexed.  Tried Ebay, Cousins etc without luck.  Any advice as to alternatives that will fit or alternative sources would be gratefully received.
