screw sizes on Swiss movements
I have an ETA 1152 that's missing one of the screws for the minute work cock.
I don't have any scrap ETA movements, but I do have a couple of Swiss movements. One's a Peseux, can't see what the other is.
What are the chances of finding a suitable screw on another brand of movement. How common are screw sizes/threads on Swiss watches ?
It's a good idea to have plenty of spare screws because you never know when you are going to need one and they are easily lost.  You should be able to buy good selections from suppliers. I wouldn't think for one minute a screw from a Peseux movement will fit E T A movements. The same goes for old Russian watch movements there screws are a completely different thread to Swiss screws. It is always good practice to fit the correct screw and size, this makes sure the two parts are screwed together correctly, the screw should be right in every way, correct in length and not long in a way it could be sticking out and interfering with something in the movement.
Any idea where I could get an assortment of ETA screws - I looked on Cousins but couldn't find any?
Ebay looks your best bet for selections, but be careful many are selling screws for glasses which you don't want there to big, but some are for watches you won't just get E T A movement screws.
Here are two more links.
https://watchpart.co.uk/advanced_search_result.php?keywords=watch+screws
http://www.ofrei.com/shop-bin/sc/productsearch.cgi
ofrei is the best here looks like they have a good varied selection.
Have a look on google that's what I just did.
I don't agree there? It could work? But as oldhippy says it's better to find some spare screws? i bought a spare screw box from  redrosteruk on ebay. I think a few others has bought that to?
Something like this i have. But have filled it with a lot of other screws from old movements . https://www.cousinsuk.com/product/all-kinds-mixed-screws-wristwatch
Here you have the screws for bridges . You can see the different sizes availible? Have a caliber and measure the screw which size you need . https://www.cousinsuk.com/product/bridge-screws-wristwatch
Edited by rogart63
Jules Borel's site is generally pretty good for looking up parts equivalents and to identify the base or most common movement in a series.
In this case however, the part you want is not listed against that movement... however they do list the minute cock, and by clicking this you can see all the other movements this part is used on. It is a fair bet that the same screws are used to hold it in place on the other movements:
http://cgi.julesborel.com/cgi-bin/matcgi2?ref=Xb\D]
I can't see the individual screw listed in any of my usual haunts, so you may be best buying a scrap movement from the same series. This may seem like a slightly more expensive solution, but you could spend a long time looking otherwise. For example:
http://www.ebay.co.uk/itm/Monte-Swiss-ETA-1080-watch-movement-dial-running-/231964492855?hash=item3602294437:g:MI8AAOSwrhlXTzcm
    • I have been recently servicing an Omega 3220A chronograph movement which uses a Dubois Depraz 2000 chrono module.  This has been quite a time consuming project, not necessarily difficult but with lots of steps.  Working on the chrono module is like working on the love child of a hugely complex keyless works and a Timex pin pallet movement. I do have access to a couple of Omega tech sheets and a couple of relevant Youtube videos (including Mark Lovick's Breitling series) so I feel confident that I have all of the required information. The 'tractor' movement (effectively an ETA 2892) had no issues with obtaining 300 degree amplitude dial up / dial down and maybe a spread of 7 seconds across all of the positions.  I serviced the chrono module and when reinstalling it, this brought the amplitude down to about 260 degress with the chrono stopped and 200 with it running.  The Omega specification states that the chrono running should see the amplitude drop by no more than 40 degrees (from, I am guessing, the assembled amplitude i.e. chrono stopped rather than just the bare tractor movement). Obviously this isn't good enough. I am going to have to redo the chrono module again.  Where I suspect I have a problem is inconsistent / over oiling of pivots.  For some reason the Omega technical guide states to apply oil to the bottom pivot of each wheel and then place in the jeweled base plate.  In practice, I managed to smear oil on the horizontal base of the wheel which would be smeared over the outside face of the jewel.  This also wouldn't be helped by dragging the wheel around trying to get the lower pivots to engage in the the jewel.  When I watch Mark service a similar Breitling chrono with DD module, he also oils the bottom pivots and installs the wheels (obviously doing a better job than me!).  My question is, why can't I install the wheels dry and the oil the jewel on the other side of the base plate in the conventional way? The top pivots are oiled through the jewels in the conventional way, so why would the lower pivots be any different? Looking at the those jewels (picture below an example from a different movement) it looks like there isn't an oil well in the outside surface of the jewel around the pivot, so perhaps I would be better applying a drop of oil directly to the jewel hole before installing the wheel?  Perhaps the jewels have different arrangement to conventional jewels because the outside face is installed against the dial side of the tractor movement and we don't want to risk oil migrating from the module to the movement. There are also a couple of friction springs that may have an impact on amplitude, I will recheck their pre-load but these should be OK.  Is there anything else I should look at as a source of friction in the DD module?
    • I found a Trupoise in a flea market box of tools (🇬🇧car boot). I preferred the ‘8’ style tool until the moment I broke my new Omega rivet. The trupoise holds the arms firmly and I’ve become quite efficient… …and I just resorted to bending a balance cock. I needed a tiny bit less shake and it seemed the least risky of the other options. I held it between a stump and a fat stake while I bent the jewel end with my fingers. Honestly I don’t know how anyone would know by visual inspection.
    • It was about 4 years ago, one was 30, another 35 and 2 others came in joblots that I was after something else. 3 have ruby jewels and one has ceramic bearings.The most I've seen one sell for is £330.  In the uk i still see them sell occasionally for around £70.  I'm not convinced that the Trupoise has low enough friction on the pivots to be as good as a traditional tripod poising tool with unworn ruby jaws.
    • I have a Record 525 which is in a pretty bad way. From what I can see it is based on a cal 650 with an automatic bridge and centre seconds pinion under the rotor retaining stud.  There are additional bearings in the train bridge for the bottom pivots of the automatic works. Of these, on has come out of the bridge completely, one is a bit mangled with an egg shaped pivot hole and one is half in, half out. I've made bearings from scratch on the lathe before, but only for pocket watch pivots (i.e. considerably bigger than these!) and these bearings are either plated or not brass, to match the bride plate, I would guess. I could not find a bridge on eBay so I started digging. I checked new Ranfft site (not help, but the new one seldom is) then the cousins download centre but I could not find a document for a cal 525. I did, however find one for the 650 and, scribbled on the page are the words "= Longines 701". So, obvious next step (or so I thought) would be to check the docs for Longines cal 701 and then see if there is maybe a cal close by, based on that cal with a rotor. I checked, no 701 in the downloads section.  I did find some Longines 701 parts on eBay, which look similar to the 650 (i.e. the train bridge looks to be the same) but I feel I have hit a dead end. I have added some pictures that you may find helpful and I have photographed the entire strip down so I have more, if needed.  I feel I have few options: 1. Close the brewing holes up and reinsert the loose bearings. Close up the pivot hole on the 3rd bearing and hope that does the trick. 2. Make some new bearings (doable but tricky and will look wrong) 3. hold out for a 525 bridge to come up online. I get the feeling this is a rare movement though (all the more a shame it is in such a bad condition) 5. See if there is a Longines equivalent and either use that, or transplant the bearings from that bridge to the Record. Any help identifying the Longines equivalent (if it exists) would be appreciated. Any suggestions on the alternatives I have discussed are also welcome
    • Really you paid that little for a legit Trupoise?
