Swiss ébauche in need of 11.2 mm Minute wheel (3.7 mm pinion)
Similar Content
Different folk use different names for parts, most often the part's function, and sometimes to describe what it resembles regardless of it's function ie .castle wheel, anchor. I particularly like all the old traditional names, they seem much simpler yet more descriptive. This one is also sometimes referred to as a set bridge with jumper spring. Setting parts bridge cover with integrated spring. Personally i think Its a good idea to learn all the variations inc. foreign names, French and German especially since parts and tech sheets are often Swiss. -
Sounds like the oscillating weight has come adrift could have have broken the axcel. If you have a good case opener just have a look, no harm in taking a look at least you will be able to tell him what is wrong. Post a good photo here and we will be able to confirm for you.
You could use a stem extender or adapter. When fitting a new crown to make sure it screws in correctly file the end so it has a bit of a point.
Same as Hector the correct size of die will feed on easier. Although you cant apply it in this case ( shutting the gate after the horse has bolted sorry about that and the pun 🙂 ) but a popular trick that is used to straighten out the end threads of a bolt after it has been cut is to have a nut threaded on before the cut, the nut is then spun off. For future you can use this method by trimming off the blind end of a crown and have that threaded on before cutting the stem. Cutting it back to the root portion of the thread will help it to enter better. How thick is the crown ? If there is plenty of thread in it you might get away with a little trimming on the stem, add something in to the crown hole afterwards to stop the stem bottoming out past the required length you need. Make sure whatever you pop in the crown is small enough to come out in case adjustment is needed. Bit difficult to do at this size, but another idea is to clip on a halved nut and back it off the stem Get yourself a screw thread polisher for shaving the ends
