Can somebody please help me read this Name?
Cougarnaut
It looks like it could be John Hargreave Birmingham and going by the dial and hands dates from about 1750 to 1800.
Having said this, I cannot find any record of this name for a Birmingham clockmaker.
With some held from a genealogy site where they decipher old writing this is what they have come up with.
It's definitely John, and I think it's quite likely to be Masgreave.
Ancestry have a number of old directories, which mention a John Masgreave in Birmingham:
Wrightson's Directory for 1815 and 1818 has him as a Brass Founder
The England Commercial Directory 1816-17 has him as a Brass Founder with the note "(clock)" after his name, and the address Summer-row
  Painted 30 hour longcase clock also called a white dial clock. Looks like a 12inch square dial, although early ones had a 10inch dial. Count wheel strike on the back plate. Anchor escapement, strike hammer I think this is a replacement they are normally in steel not brass and doesn't look the same brass as the rest of the movement which has four pillars. Very large bell this I would expect to see. One thing I'm not happy with and it might be down to the photo you have taken of the dial and movement side on, it looks as if one of the dial feet has been forced down to fit the movement, is this right or is it the photo deceiving me only there's no sign of strain or paint cracking on the painted dial which makes me think it's the photo. 30 hour types take a hell of a lot of wear it is the full weight that force these clocks to keep going, when they stop expect a lot of work to do. When winding these 30 hours up take the weight and pull the chain so you are taking the full weight yourself.
Hello all,
It is definitely John Masgreave, he married Elizabeth Harlow in St Oswalds Church Ashbourne on 22 June 1807. Elizabeth was the daughter of Samuel Boulton Harlow another Clockmaker. they are on my family tree.
Cheers,
Vic
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
