I recently found this watch in an old travel bag,
I remember buying it on a cross channel ferry sometime in the 90's, actually not a bad watch it has an illuminating dial a bit like a seiko lumibrite, but it came with a rubbish velcro strap.
A new battery, clean & re grease seals and a new silicon strap from Cousins and it's back in the collection !.    :D
Each to his own - whatever turns you on! I've never  been interested in Sekondas - which is not a criticism, just my personal preference - but I suppose, from time to time, I've worn a Sekonda-type movement under the name Poljot or Raketa or whatever. Before 1993 they were Russian movements. After that time, roughly, they imported Asian movements and became a British distributor of watches.
I have a love affair with Sekonda watches, for some reason unknown to me :)
Thanks for the comments guys !
It's interesting to know a bit of their history, I probably bought this one in the mid 90's for no more than about 15 quid and
it has a Japanese miyota movement in it that's very similar to the one in my Rotary watch that cost £100 + !   :)
    • I have no experience with this watch, but looking at the pictures from the ebay listing linked above, it looks like the outer metal bezel at the back of the watch may not be part of the case proper.  It looks like the watch and strap are sandwiched together, and an inner case may push out of the rear bezel towards the front of the watch.  A case style similar to the Roamer watches where the crystal, movement and caseback pushed out through the back of an outer bezel, only in reverse - this one may push out towards the front.  To test this, you would need to hold the watch, dial down, supporting the dial side of the watch around the edge of the bezel without touching the bezel itself. Then push down carefully on the inner metal ring you can see at the back of the watch. I’m speculating here, proceed at your own risk. Hopefully someone with hands on experience of these watches can chime in! Best Regards, Mark
    • Thanks, Mark. That's the kind of reassurance many of us wanted to hear! Yes, life is unfortunately unpredictable, and it would be a shame if the many dedicated WRT: ers became stranded if, god forbid, something happened to you and WRT stopped working.
    • The case back is perfectly aligned to the case and has no provisions for a screwing tool. The T-Sport series has snap on backs.
    • For me the text looks too aligned and with no obvious way to grip as a screw back.
    • There’s no indents & there’s no little groove to pry it off anywhere! So I don’t know if it’s screw down or pry off 👍
