Landeron 48 with aftermarket dial restoration
Some of you already know that I bought myself as a birthday present, and to celebrate the birth of my first daughter, a Landeron 248 based Chronograph to restore / fix, and that I thought that it was a redial. Here the thread about it:
Apparently it is not only the case ot a simple redial (albeit with a wrong dial which was adapted) but what I would define as "watchmaker's botchery", since the dial itself was fixed to the case with 2 screws (and from the front side...):
The dial is all wrong... having also some numbers hand engraved as you can see above the 60 / 12hr mark and at 1.
I really don't care about the dial, since I have some original spares here with me and I was actually looking for a case and movement to complete a watch.
The case apart from some light scratches due to apparent wear is fine, so is the glass. I will disassemble the movement and post pics as I do it. Stick around...
6 hours ago, GeorgeClarkson said:
If the moderator can remove the "248" from the title and tags, please.
That's it sorted George.
I look forward to seeing progress on this one, this was the first type of chronograph I repaired.
Thanks Geo.
I was able to make some steps forward: i disassembled the entire movement and cleaned it, then reassembled it and noticed that the dial was not the only issue: the balance wheel had the upper pivot broken off and the balance cock was a bit bent downwards.
I tried replacing the complete balance wheel keeping the air spring, bit something was touching the wheel thus slowing it down.
So I went for a more drastic solution: I replaced the balance Assembly altogether (wheel, air spring and cock) with one spere I had and apart the fact that the beat error is huge, it works...
  • 2 months later...
Just following this adventure George! Seems you are quite a wizard solving what seems to be unsolvable! Good going and yes, please, show us your progress!
Cheers,
Bob
PS. Looking at those screws in the front of the dial I can't believe someone "fixed" the watch that way!
I just managed figured out I didn't upload the pictures of the work don on this watch, thanks for reminding me, bob;)
So here it goes...
Since the L.48 had some issues, I swapped it with a L.151 which is dimensionally identical, of course. This movement needed only a good service, or I thought so...
So I started removing the dial, removing the screws that were holding it.
Edited by GeorgeClarkson
Since the battery of the digital camera decided to take an unexpected break, I have no pictures of the disassembly, unfortunately. All I can say is that I removed the movement from the case, and proceeded to remove all the parts, one by one. When I finally got hold of new batteries, this is the status I was in:
And the digital camera failed on me again... not the battery though, it had other issues apparently, so no more disassembly pics, I am deeply sorry.
Anyway, suffice to say that this movement needed a complete service and a couple of parts, so I decided to swap it with a L.151 I had and that had a couple only of resolvable issues, which where a missing spring and a not correctly set driving wheel.
  • Similar Content
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
