Thanks, the one I currently have has a clamp, but looking at some of these posts it looks under powered. I was looking for something with adjustable brightness that at full power would pull aircraft off course 🤣
I was looking at this (link HERE):
But it seems expensive at £75.95 and I don't know if the performance is worth this cost - are there more 'bang for the buck' options out there?
I bought the L60414 from them a couple of years ago and I've been very happy with it. The one you've selected has a larger head and more LEDs, so quite possibly worth the extra.
Very informative thread! After reading through, I ordered a lamp from Amazon. Under $49 US (£39) tax shipping and delivered in 6 hours, yep! This one has 5 intensity levels and 5 color settings from 3200 to 6500. I use a binocular microscope and have the gooseneck lamp in case I need directional light. Don't mind the clutter of watches, those are usually moved off the bench when working on a watch. This really lights up the area nicely. The ring of leds on the binoculars is fairly cool when compared to the new lamp. I like it because once set it returns back to the setting when turned off and back on again.566958909_20230528_2023432.thumb.jpg.6c0677c1561d544d660b040725c90bd6.jpg1116591457_20230528_2156423.thumb.jpg.dd2bcffdb7071d01f3ce45522d310622.jpg
Could you share the like from Amazon where you bought this? Thnx
6 hours ago, Waggy said:
That looks like it. I will try to post the Amazon one.
6 hours ago, oldhippy said:
What a nice light and it hardly takes up any room and its not expensive at all.
Yes, and it doesn't give off much if any heat. Slight bit to the touch but not anything noticeable after a few inches away. There are 2 light bars that move independently up to 90 to the front/side. The light bar attaches to a bendable post, so can be manipulated a bit for height as well.
"Ksunun Double Head LED Desk Lamp, Architect Desk Lamps for Home Office, 24W Brightest Workbench Office Lighting-5 Color Modes and 5 Dimmable Eye Protection Modern Desk Lamp for Monitor Studio Reading"
Not sure how to copy the link without private info, but this is the exact product listing description.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
