Well - it's definitely a Ronda but it's not clear which one and there are quite a lot that look the same but with slight, but important differences.
If you look closely all over the movement you will see a three figure number (possibly starting with 7).
Also - it looks like the battery isolator is not seated correctly. Are you sure the battery isolator is not the cause of your problem. Take the battery out and make sure the isolator is tucked under the negative contact properly.
I originally fitted the battery as I thought it had gone flat, however it didn't work so took it the watch repair shop in Debenhams who said the movement is knackered and was cost £45 to replace.
 The battery is how is was returned from them so will double check it just encase.
Can you tell me roughly where there numbers should be? I can see something on the movement (shown in pic) but its too small to read (haven't got a magnify glass so took picture and tried to zoom in on it!
The resolution is too low. When I blow the picture up it goes pixelated and you cannot read the writing.
As I mentioned there are many models based around this design so its very hard to go by looks alone. The number is important.
Can you upload a higher resolution to flikr or similar photo site so we can get a closer look?
  • 2 months later...
Thank you Luke and welcome to the forum.
I can vouch for Gleave and Co. as being a reputable company.
Thank you Mark, I also made this document a couple of months back to help people identitfy quartz movements.  The most difficult arethe rondas (often on the black plastic or hidden deep in the middleof the movement.  Also miyotas based on the popular 2035 are sometimes not stamped.  These are 2035 or 2115 (Date version) 90% of the time but there are at least 20 movements based on the 2035!
http://www.gleaveandco.com/fileuploader/download/download/?d=0&file=custom%2Fupload%2FFile-1390594830.pdf
4 o'clock date discs do not align perfectly with 3 o'clock date discs. However many watch brands want to use the 3 o'clock movements as it is much cheaper than having 4 o'clock ones specially produced. Therefore they put the date with just slightly off the 4 o'clock marker which you would only notice if you are looking for it. So if it is bang on 4 then you would need to change the date disc with the old one. But I would guess it is slightly off the 4 and the 3 disc would line up.
    • This is the old/first(?) way for making a mainspring for an automatic. "Evolution-wise" it is an logical first step forward from a standard spring. Usually these are indeed replaced with a new spring with an integrated/fixed bridle. Lubrication as you would do with any automatic.
    • I'm working on a Schild AS 1250 (a 'bumper' automatic) and it's the first time I've seen a mainspring like this. It has what looks like a regular manual-wind mainspring with a 'hook' at its outer extremity. On a manual-wind watch that 'hook' would engage with a 'hook' in the barrel wall to prevent it from rotating. However, the AS 1250's mainspring does not engage directly with the barrel but rather with a 'sliding bridle' that sits between the mainspring and the barrel wall, and evidently facilitates the slip necessary in an automatic. I'm not sure what advantage this two-piece configuration provides, but it highlights a gap (one of many) in my horological knowledge. I'm not sure if 'hook' is the correct term as used above, but please see photo below to see what I mean. Therefore, two questions please. 1. What is the proper way to lubricate a barrel from an automatic watch with a sliding bridle? My guess is the same as any automatic ms/barrel (e.g, a few dabs of braking grease on the interior barrel wall). What do the experts say? 2. I purchased a Generale Ressorts GR3472X mainspring, made for the AS 1250. It looks like the bridle is included and I don't need to salvage and re-use the old one. Is this a safe assumption? Thanks for the advice. If you have any other wisdom you'd like to share about separate sliding mainspring bridles, I would be very interested. Cheers!
    • Thank you Hector. You too matey 😊
    • Bless you, Mark. May you live long and prosper!
    • That’s a nice idea, But i’m committed to providing this site as a gift to the watch repair community as my thank you for my incredible life i’ve had in this business. Ive done well and unless my financial circumstances change then i’m more than happy to foot the bill. If circumstances do change then be assured that I will make an appeal. For now, I’m comfortable with the way things are and I am extremely delighted to remove Google Ads from this site and to stop Patreon, it feels like a major step forward 🙂 Sorry, I missed your reply, I got blinded by another poster in this thread. Yes - I can confirm that I have always seen WRT as a not-for-profit website, and therefore - not a business as such. I’m lucky and have done well in my life due to a decision made in my teens to start a watch repairing apprenticeship which has sustained myself and my family for many years now. Consider this my small way of paying it forward. Ive been committed to keeping the site alive on a technical and financial level for over 10 years now and I have zero plans to change that. Thank you for your kind words by the way. And as for your wish - nobody can control what happens in life, if something happens to me I have things in place with my family but I’m just not comfortable talking about my personal business - I wish a certain person would respect that, but i’ve calmed down now - i’m only human 😄
