Im curious to know if any of you fine folks know how to exchange a rotor on the ETA 2824, by which i mean retaining the centre bearing and swapping the old rotor weight for another. Is the bearing a push/friction fit/removal ? I know on the 2892 and other models to use the removal tool but i want to be sure before i damage any parts.
I have looked through my ETA Technical communications but there is no explaination for the procedure so i figured one of you fine chaps might know the correct method. Any help will be gratefully received :)
Excellent :D
Not sure how i missed this video but the procedure is exactly as i thought. Looks like i'll be making some new staking tools for the job at hand :)
Cheers Cad ( & Mark ) your both stars :)
Turned up a quick staking bit for the rotor bearing and practised on a scrap 2824 rotor with smooth sailing. Cheers for the help :D
Its funny how you know what to do but in your head you say " is that right ?? " and despite years of doing this job there's always something new to learn:)
  • 7 years later...
Hello all,
I'm reactivating this old thread with a question.
I've of course watched Marc's video.
I'm just wondering if that pin in the center of the anvil he's making (on the lathe to push out the bearing) is really necessary.
I have an anvil that has a hole just the right size to fit the bearing and hold the rotor, but it doesn't have that center pin.
I've seen other videos online where people do without the pin.
Cheers
Edited by Knebo
No, of course not. I guess it's just Mark's sense of humour.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
