Very nice!
I have a friend that snatched an old card catalog cabinet from a library when they went electronic. He stores wine in it, but I always thought it would make a great parts cabinet.
Something like this -
  • 7 years later...
I had a cabinet  with a few draws, I had wooden trays fitted for the insides and small transparent plastic boxes that would take a watch movement and its parts all the boxes had small labels with the cal on them. I called it my A to Z of watch parts. This you might like to think of.
On 8/11/2016 at 5:39 PM, dadistic said:
Very nice!
That looks like a pull-out shelf in the middle very cool.
On 3/19/2024 at 11:46 AM, Neverenoughwatches said:
Post revival 🤣 , just picked this 60's bedroom chest of drawers for tool and part storage. There is some great ideas on the this thread.
Yours looks a tad more stylish than my dresser. My wife wanted me to get rid of it as it was only holding clothes we no longer had a use for and it was taking up space. I was about to put a 'free' sign on it and put it by the curb but then realized it would work perfectly in my little watchmaking space.
32 minutes ago, GuyMontag said:
Ooo tell me more about tehse dividers!
I got some vintage Bulova parts drawers from eBay that I love the look of, but the drawers are too shallow to be really useful.
I've got a few of those Bulova parts drawers too, but mine are all full of parts 🙂
The dividers in the photo are not great. I ordered 10 of them (at around $3/each delivered) from Aliexpress as a trial as I would need around 35 of them. They are difficult to adjust to the correct length due to how they are designed. Each increment is too large such that if you extend them to the point where they are slightly too large and won't lock but then back off one increment, they are then too loose. I ended up 3D printing some shims to get them to fit somewhat snugly.
My next attempt worked out much better. They are sturdier and are easy to adjust to the correct length. I got them from Amazon and they worked out to about $4/each.
I still need more space for my tools and miscellaneous parts. I have stuff just sitting on the floor as I am 100% out of storage space in my room. I ordered the 7 shelf version of this yesterday to help with parts storage and make more room on my work bench as it is currently cluttered with tools. It's only 12" deep but I think/hope it will help create some much needed room.
Edited by GuyMontag
Fits like a glove, i would go so far as to say that it looks like it grew there. I like the dividers.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
