a BIG hello from Chester
AP1875
Hi guys,  what an amazing hidden gem i have stumbled across! I have been interested in watches for many years but mostly from an aesthetic point of view. I have recently developed an itch that needs scratching in watch repairs, i can't help but to want to take every watch apart and take a look inside!! So i'm so glad i found this place.
I have recently spent a bit of money on some tools and a couple of movements. I'm currently taking a 6497 apart (nice and big haha) and i'm finding it amazing.
Anyway, i've pledged some money and signed up to Marks course (although i can't actually view any videos??)
Rob.
Hello and a big welcome glad to see you've found us here at WRT the best watch repair forum on the net. You'll learn alot by taking Marks repair course but I don't understand why you can't see the videos.
Welcome Rob from...Bob! :)
You are on your way to a fascinating side of watches, how to put them together...although we all start by taking them all apart!! Oh, well, no matter as long as eventually they tick again. So, let us know of your progress!
In the end, I'm sure you'll get this from future friends/customers (seeing you with "laser" screwdrivers and referring to Mark's training classes)  : "Your master has taught you well, young padawan!" :)
Cheers,
Bob
Hello Rob and welcome,
Good to see that you have decided to support Mark, he has in the past taken some flack because he has decided to help out the lesser informed such as I and the knowledge he has imparted has been beneficial to us all.
if you are taking a movement apart don't forget to take pics before and after each stage as it helps when you put it back together and if you have time to post them it is gratefully received by the members.
cheers,
Vic
cheers,
Vic
Why would anyone give someone flack for helping others? What he has done/doing is quite incredible.
And yes i'll be posting some pics, i could really do with some help with the pallet alignment with the escape wheel......
Because some watch repairers think watch repair is for the chosen few and not to be meddled with by us mear mortals. Post your pics oh wait a minute will it upset people if we help naaa who gives a @#$¥. :D
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
