Well,
It turns out my Dad's 1960's Jules Jurgensen watch has a Peseux 330 Movement.  I've got this info on the mainspring  from http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&0&2uswk&Peseux_330
Mainspring / battery
Zf781, 1.25 x 10.0 x 0.12 x 290mm
What I don't understand is what these numbers correspond to (except for the 290mm is for length) order a new mainspring.
Thanks for any info,
Dan B.
Well,
Dan B.
1.25 = Height
10.0 = Inside barrel diameter
0.12 = Thickness (Strength)
290 = Length
Hi Dan,
Zf781 Part number
1.25 Width of the spring
10 Barrel diameter
0.12. Thickness
290. Length
All sizes in millimetres.
I thought you were hiding Mark, I must have been typing as you posted! :-)
Indeed I was lol :D
    • By the way, I opened my watch, looked under a magnifying glass, there is simply no grease, the screws are without traces, the slots are intact.I think it's just a matter of maintenance.there are no rotor marks on the body. And to remove the strap from yours, just press on the 1st side,and slightly move the strap, then on the other side and it will come off.
    • Hi My name is Chris. Just started trying to learn about watch and clock repair as a result of repairing my fathers old 1890s police station clock (about a year ago). The clock was Ok, but having graduated to pocket watches and then wrist watches, despite the really excellent stuff on Youtube, I am struggling a bit.  As a retired engineer, I find the engineering exquisite, but a bit on the fiddly side.  I have done a few practice watches with a little success but failed a few, but have had success with Seiko 7005s, 7009s etc, but have just attempted a citizen 5430.  Nightmare.  My wife thought I had found religion as I spent so much time on my knees with my eyes to the floor looking for springs.  Got through that and found that the balance is shot.  Trying to source one or something that will fit from the citizen range has me totally perplexed.  Tried Ebay, Cousins etc without luck.  Any advice as to alternatives that will fit or alternative sources would be gratefully received.
    • I have only been a member for six years & I have found this a very friendly forum although I don’t have anything to do with watches not because I don’t like watches but because I have gout in both hands so my dexterity isn’t very good, I restore torsion clocks & occasionally other antique clocks also at 72 my eyes are not what they used to be, that is why I only post on the clock forum & the lathe forum mostly . As others have said Mark it is much appreciated that  you are willing & able to do this. very many Thanks Dell
    • Ah, this is brilliant, thank you very much!
