Hello all
Im a newbie to watch repair as a hobby. Ive just been gathering up some basic tools and now I've jumped in head first on my first project.
Its a poor divers watch that got water damaged, its got a Mitoya 8215 in it and its rather sad, with a rusty old balance wheel. Baptism by fire.....what could possibly go wrong??
:D
Stoo
Welcome aboard Stoo from an auld Scottish git.  There are plenty of folk on here to help you out, all you have to do is ask. :)
18 minutes ago, Stoo said:
Hello all
:D
Stoo
Welcome Stoo, everything and anything "Can go Wrong" & probably will , in My case
Thanks Geo
Im very likely going to need that help, I've just realised tonight that while waiting on the spare balance wheel for this Miyota movement I've forgotten what way the mainspring goes in, left.....or right....or ma other left....ooops! the learning curve is steep.
Cheers
Stoo
Welcome Stoo! That's a nice, tough movement you are working on. Show us some pictures when you have the chance. Also, some of the experts can help out in case you get stuck with something so ask away!
Cheers,
Bob
Greetings!
Hey, that's the way it goes. I've set aside several watches that were a bit too involved for my skills at the time, some of them I;ve come back to, and succeeded with.
    • The ones I have opened also do not have a pry point , hence the reason for the tool. The watch is clamped in the tool and a blade is screwed into the seam, the blade being chamfered lifts the back then the screw shaft is turned and the back comes off have a look on Ali express for case back removal tools
    • I don't think I need to know more about the Orient watch question, so please don't write anything related to the topic, but if you know where I can buy the watch's jewels = rubies and gems shock protection, I would like to know.
    • It's an exhibition back so no access as you suggest.
    • I have no experience with this watch, but looking at the pictures from the ebay listing linked above, it looks like the outer metal bezel at the back of the watch may not be part of the case proper.  It looks like the watch and strap are sandwiched together, and an inner case may push out of the rear bezel towards the front of the watch.  A case style similar to the Roamer watches where the crystal, movement and caseback pushed out through the back of an outer bezel, only in reverse - this one may push out towards the front.  To test this, you would need to hold the watch, dial down, supporting the dial side of the watch around the edge of the bezel without touching the bezel itself. Then push down carefully on the inner metal ring you can see at the back of the watch. I’m speculating here, proceed at your own risk. Hopefully someone with hands on experience of these watches can chime in! Best Regards, Mark
    • Thanks, Mark. That's the kind of reassurance many of us wanted to hear! Yes, life is unfortunately unpredictable, and it would be a shame if the many dedicated WRT: ers became stranded if, god forbid, something happened to you and WRT stopped working.
