Timex 905 movement crown
Oh wise and wondrous watch gurus....
I have a Timex T49878: https://www.amazon.ca/Timex-T49878-Expedition-Military-Field/dp/B006KY5V0O
It has sentimental value and I am trying to get it working again.
Specs:
Caliber: M905
Linge Size: 13½
Thickness (MM): 3.65mm
Hand Size: 120/70/20
Stem: 401-2017
Cell/Battery/Power Source: 2016
Tap Size: 10
Includes: Protective Case, Stem, and Power source.
Other Information: INDIGLO
I managed to find a new stem (401-2017)
Now I need a crown and it looks like a short post is used to operate the “glo”, but it isn’t clear what the length of the post.
Can anyone identify a crown that I could use or indicate what I should be looking for ?
Thanks for the prompt reply. Much appreciated.
Unfortunately, Cousins customer service has been either unwilling or unable to answer this question.
I ordered the stem from Cousins and asked what crown I could use but so far all I have received is a runaround to what would seem a simple question from a company that theoretically has a expertise in this field.
So far I have received a better reply from Chinese sellers on eBay than Cousins.
Hi MilTime,
Although I'm not familiar with Timex watches much, if you only require a crown, -- and you don't have the original -- you need to estimate the dimensions and find one among the supplier's listed ones. That's normal procedure....
Cheers,
Bob
On 9/7/2016 at 9:36 PM, bobm12 said:
Hi MilTime,
Cheers,
Bob
Many thanks Bobm12
Very useful info, new to this so its like groping in the dark at some points.
I found a hi-res pic online that is getting me closer.
I am waiting on the delivery of a digital caliper to measure the stem post on the case.
I suspect from the picture below that the rubber seal(s) are on the inside of the crown and the crown covers the stem post for waterproofing.
So once I can measure the stem post on the case, I suspect that I will be moving closer to target.
Correct, you need to measure the tube (outside diameter) where the crown inserts (case side). You will also measure the clearance where the crown will eventually sit (case side). Finally you will eye ball (with the help of the caliper if you would) the height (thickness?) of the crown or to be more specific, how much would it, once seated in its normal watch wearing position, will it protrude.
Eventually you will find a standard crown (water proof) that will fit the dimensions you come up with plus or minus...not really exact.
Esslinger makes the choice a little easier because of the way their page is structured so that would be a starting point to check on dimensions. Afterwards you can order from your preferred supplier. I would go by the ones without post (fail safe) unless I know the diameter of the post will fit the tube (inner diameter of tube).
Many thanks for that Bob, thats extremely useful information !
Now I am moving forward ! :biggrin:
Edited by MilTimeCan
Most Timex watches that I had the misfortune to handle all those years ago. The buttons just pushed on, the stem never had a thread to take a screw on button. We used to send the little buggers to Scotland I think it was Dundee, someone on here will tell me If I've got the wrong town. The reason we sent them away they were not worth repairing.
Very useful Bob !
The calipers just came in the mail.
The Tube Opening OD is 2.5 mm and the case thickness is 6 mm.
I am closing in on a candidate (below)
The post length is the last point of contention, its not flush and 1mm looks a bit long if I take the picture above into consideration.
On 10/2/2016 at 0:25 AM, bobm12 said:
That looks like a winner MilTime, let us know how you get on. Remember to add a little Loctite 222 to the threads of the stem...
Cheers,
Bob
Bob,
Finally got the crown.
Getting closer but not quite there yet :blink:
The stem and crown mate but not fully :huh:
But the watch movement does work again :woohoo-jumping-smiley-emoticon:
Not quite sure what the next option would be.
The crown doesn't fully insert into the tube, it protrudes significantly when fully inserted.
Now that I have specs, I am wondering if I should try a different crown or all they basically all the same in manufacture ?
Having never done this procedure, I am a bit reluctant to cut the stem with the threading.
Thoughts ?
    • I found a Trupoise in a flea market box of tools (🇬🇧car boot). I preferred the ‘8’ style tool until the moment I broke my new Omega rivet. The trupoise holds the arms firmly and I’ve become quite efficient… …and I just resorted to bending a balance cock. I needed a tiny bit less shake and it seemed the least risky of the other options. I held it between a stump and a fat stake while I bent the jewel end with my fingers. Honestly I don’t know how anyone would know by visual inspection.
    • It was about 4 years ago, one was 30, another 35 and 2 others came in joblots that I was after something else. 3 have ruby jewels and one has ceramic bearings.The most I've seen one sell for is £330.  In the uk i still see them sell occasionally for around £70.  I'm not convinced that the Trupoise has low enough friction on the pivots to be as good as a traditional tripod poising tool with unworn ruby jaws.
    • I have a Record 525 which is in a pretty bad way. From what I can see it is based on a cal 650 with an automatic bridge and centre seconds pinion under the rotor retaining stud.  There are additional bearings in the train bridge for the bottom pivots of the automatic works. Of these, on has come out of the bridge completely, one is a bit mangled with an egg shaped pivot hole and one is half in, half out. I've made bearings from scratch on the lathe before, but only for pocket watch pivots (i.e. considerably bigger than these!) and these bearings are either plated or not brass, to match the bride plate, I would guess. I could not find a bridge on eBay so I started digging. I checked new Ranfft site (not help, but the new one seldom is) then the cousins download centre but I could not find a document for a cal 525. I did, however find one for the 650 and, scribbled on the page are the words "= Longines 701". So, obvious next step (or so I thought) would be to check the docs for Longines cal 701 and then see if there is maybe a cal close by, based on that cal with a rotor. I checked, no 701 in the downloads section.  I did find some Longines 701 parts on eBay, which look similar to the 650 (i.e. the train bridge looks to be the same) but I feel I have hit a dead end. I have added some pictures that you may find helpful and I have photographed the entire strip down so I have more, if needed.  I feel I have few options: 1. Close the brewing holes up and reinsert the loose bearings. Close up the pivot hole on the 3rd bearing and hope that does the trick. 2. Make some new bearings (doable but tricky and will look wrong) 3. hold out for a 525 bridge to come up online. I get the feeling this is a rare movement though (all the more a shame it is in such a bad condition) 5. See if there is a Longines equivalent and either use that, or transplant the bearings from that bridge to the Record. Any help identifying the Longines equivalent (if it exists) would be appreciated. Any suggestions on the alternatives I have discussed are also welcome
    • Really you paid that little for a legit Trupoise?
    • Nailed it Andy 👍 It kinda was, but had a happy ending all the same.
