so i finally got around to playing around on the lathe (that i purchased over a year ago)
i needed to try and create a hand setting stem that was missing for a pocket watch - knowing what it looked like i measured what was needed and had a go.. this obviously is not a balance staff but it was my real first attempt at an actual repair using a watchmakers lathe... im happy with how it has turned out and look forward to learning more on the lathe when i get a chance..
obviously this post is useless without pics sooo...
Start off with a bit of blued steel
Turn the steel down to the size required to go through the watch
yep..
you can see the it poking through
filed down the end to size and checked the friction fit of the the wheel
using the indexes on the late i worked out the 4 positions required to get a perfect square and started filing on each side.
progressing
onto the next side..
keep on measuring until it was the correct size for the watches key
once happy i cut off the part from the remaining stock
requires a bit of polishing to get the edges crisp
the finished part with the attached wheel on it
Video attached showing the function..
VID_20160910_190857.mp4
Edited by jnash
  • Like 7
Very well done to you!  I too have a lathe, but its needs not just restoring, but also tools to go with it like collets, and shanks?  The pieces that connect to the slider to cut objects.  Got a lot to learn thats for sure.
Hi J,
I'm interested in knowing the particulars of your lathe...can you tell us the specs...I don't know much about lathes but I've been looking around for one and this one is appealing to me. I learned to work on the big ones back in high school...I don't even remember much but I used to be good! :)
Cheers,
Bob
The lathe used in this post is a Sincere Watchmaker Lathe (also marketed under the name Vector) and is a great machine. I purchased one about 10 years ago for $450.00 which included a cross slide, collet holding lever operated drilling tail stock, and free shipping. I also purchased every accessory they had which included the vertical milling attachment, dividing plates, extra long base and the sensitive drill press conversion kit. Although the price has increased over the years, it is still the best watchmaker lathe for the investment dollar, new or used, and will hold its own with any other Geneva style cone bearing lathe.
david
david
spot on.. i need to get it back out and start playing around with it.. hopefully the holidays will give me some time!
What a great job. As others have said, I expect that you're looking round for your next project now? Be great to see that one too..
Just as an added note. The motor for the Sincere Lathe is a quiet running induction motor and does not sound like a kitchen mixer when it is running.
david
