Good evening all,
I am in the middle of repairing my Omega Seamaster Aqua Terra which houses an Omega 4564 Quartz movement. The second hand had appeared to have fallen off after I'd dropped the watch but after disassembling the watch it was clear that the second wheel pin had broken.
Here comes the problem. Of course, being Omega I had anticipated getting parts from them would be impossible so I looked a little further and realised that the Omega 4564 uses an ETA E64.111 base. After looking around, I couldn't find anywhere that would sell the second wheel alone so without thinking I decided to order the E64.111 movement complete. The idea was to remove the second wheel from this new E64.111 and use it to replace the broken one on my Omega 4564...
This is where you will all join me in face-palming...and I bet most of you will already know what's coming...
The height is way off. So much so that it doesn't even manage to peer over the minute wheel when assembled. A real rookie mistake.
Does anybody know know the height of the Omega 4564 second wheel pin? I'm finding it hard to get a precise measurement using the broken pieces. Also, if anybody has one spare (long shot) or knows where I can source one that'd be great!
Has anybody worked on this movement before? I found the reassembly of the train wheel bridge particularly challenging on this one so if anyone has any tips or hacks for that I can remember for the future.
Thanks in advance for any help.
David
53 minutes ago, clockboy said:
Thanks Clockboy, this is about as far as I got. I'll have to bite the bullet and get the entire movement from eBay.
Thanks for your help :)
It looks that is the only way for now. If in no hurry it will be with a wait to see if any 4564 watch appears on the Bay for spares & repair.
That is not the only way. You could also ask an Omega service center for a repair estimate. Also, a new shaft could be turned and replaced to the existing wheel by an experienced watchmaker.
  • Similar Content
    • Books, or some sort of voucher to a material house if they do them. You can never read and learn enough and if you find a material house that could do a gift card then the person could pick things they really need.   Tom
    • I don’t know what a pivot locating tool is? I am not a clock guy though but everything else you mentioned cousinsuk should be able to supply without issue. you might get more results if posting in the clock section of the forum.   Tom
    • I came up with a topic that might be helpful for partners, friends, or family members of watch enthusiasts: gift ideas for people who are passionate about watches. Of course, more watches are always appreciated, but what are some other gift options related to this hobby or collection? What related gifts would you love to receive?
    • Thanks to everyone for the welcome.  Can I ask for some advice?  I have a French Drum clock which I am hoping to dismantle, clean and mend a bit for a friend (it is a long time since I did this, but I would like to restart). I used to go to M & P for supplies but it seems they are out of action at the moment.  Is Cousins a good place for supplies?  I think I will need: 1. Some small watchmaker type screwdrivers 2. Cleaning fluid to put in a bath and agitate the parts in (I don't have an ultrasonic bath and was not proposing to get one) 3. Clock oil 4. Some thin nosed pliers for removing pins 5. A basic magnifying eyeglass 6. A pivot locating tool 7. An assembly support for the movement 8. Some assorted pins .. but probably nothing more than that for the moment.  I don't think I will need to rebush any holes although I do have the tools for this.  The hour wheel is broken but I hope I have sourced a replacement. Final queries:  a. the wooden case has split a bit.  To glue it together, would standard strong PVA glue e.g. Evostik interior wood glue be OK?  b. to polish the exterior brasswork of the face and rear, is Duraglit OK, and should they be lacquered after polishing?  I am not proposing to polish and lacquer the movement itself, unless that is vital, but only to clean it in the cleaning fluid. Thanks in advance and I hope this is clear.
    • Thanks Mark. I think I’ll leave the beat error for now - it’s a fixed stud so I’d have to adjust the collet position.    The watch has bigger problems. On reassembly I’ve found that the hour counter reset hammer is broken - I didn’t do it, the main hammer part was just not there. Can’t easily identify a replacement part. And the subdial hands. The running seconds hand needs an extended pivot tube as the pivot is below dial level. Can’t find one of them either. I’ve found a central seconds hand that might fit it - going to have a go at cutting, filing and polishing it to make it work.
