A friend of mine asked if i want to make a stem for him. I have improved my hardware and wanted to try so happily accepted :)
Not in the Dremel now. Here the pulley wheel is serving as a dividing plate with 4 holes making sure that the rectangle cross-section will be perfect. Turning with help of a microscope, no loupe at all.
A thin glass strip is hot glued on the "T-rest" which has two purpose. The file is sliding on it easily and it is making sure that the sides will be parallel.
Still a lot to file down.
The workpiece is a spoke of a Chehoslovak Favorit road racer. Even tungsten carbide is softer if hardened.
  • Like 5
2 hours ago, nsg1tausend01 said:
Wow , very nice.
Congrats on your skills and know how.
Regards
Robt
Skill and know how? :(    :)
Finaly i got something similar to a winding stem.... for the 6th try....
M1.2 thread done. The stem here was turned down to 1.15mm to make sure it wont break while tapping.
After heated to red and dropped in brine. It is so hard and brittle, i can hear it whizzling near my ear :)
Using my special top quality heating pan
Annealed. Not as shiny like on pictures one can find on pro-watchmaker school sites, but the color tells me the temperature and that is important.
 And the best thing is, i dont had the movement. So there might be a big surprise for the guy i made it if it wont work :)
Edited by szbalogh
On 2016. 10. 18. at 0:00 AM, MilTimeCan said:
I am in awe.
Wow, I worked on a lot of plastic model aircraft parts in my younger days, but I have never seen anything like this.
Sir, you are a pro !
Not a pro for sure :) Just so excited while discovering this new watchmaking world. For an experienced watchmaker this is an every day job :) And i am sure i could make it better. For example if i had a glass fiber scratch brush, then the bluing would be better. Also i am not satisfied with the setting lever slot.The rectangular edges here are not perfect. I will have to grind a better graver to cut this type of slots.
Made a video of this project, threading included.
Edited by szbalogh
  • Like 5
    • I put the original broken glass (whats left of it) behind the acrylic. This is how it originally looked like. A cheap clock but I like it. Very noisy when the alarm comes wake up guaranteed! 🙂
    • Update!  I've dismantled it, cleaned all the glue off, and rebuilt and lubricated the base movement. I'll leave the chrono part for another day. It's running well - great amplitude and keeping time, but it's got a beat error of 4.8ms.    How important is it to correct this? I'm worried that the potential for making things worse having to take the hairspring off and on repeatedly to adjust this. Would anyone here accept it at that?
