Wanted Threads
I note that we're not allowed to post sales ads on the forum which is accepted and understood but are we allowed to post wanted/hard to find parts threads at all. For example I'm struggling to find a mainspring barrel and/or a 16s hairspring without having to buy a watch for parts and because they're American (Waltham/Elgin) they seem to cost more over here than over there.
As old hippy said, if you need to find a part, you can google it or ask in the forum for advise. Someone might have already had some luck finding it and provide who they have contacted. Other than that, you realize this is just an "experience exchange  forum", mostly educational, and not an e-market site so a section of wanted stuff is not a good feature to have. In addition, as per our rules, it will be a violation. That said, a question asking for input about the part you need or a solution for that matter, is perfectly adequate. I hope this is of some help.
Yes. I get the idea of the forum, I've been lurking for a few years. I realise I've not many posts but I find it's sometimes better to read (or watch youtube!) and learn than asking what could be considered the usual newbie questions. That's the main reason I asked the question, I didn't want to just post, I'd rather ask in this instance.
It's just that I tend to stick to pocket watch movements and I never buy them working, I prefer the problem solving and I love the damaskeening on the American Walthams and Elgins. This in itself is okay as some parts like balance staffs are fairly common on Ebay as oppose to trying to get some Thomas Russel or Lancashire Watch Co. parts, however, for example, trying to get hold of something like a mainspring barrel for a Waltham is proving difficult. I've asked on NAWWC and the Americans seem reluctant to post and I don't like buying watches for scrap as I end up trying to fix them too and I've got about 20 awaiting repairs at the minute. The Walthams and American stuff on UK Ebay is usually overpriced too I find and there's not many basket cases around.
Thanks for the replies.
According to my Waltham Serial Number Book, this S/N is a Model 1894, Grade 210, Size 12, 7 jewel movement, is this correct? circa ~1920
I thought I might have a barrel I could give you, but I do not have one of those in my parts movements. I will check a few sites and if I find one, I will private message you and give you a link.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
