Hi all!
From the Netherlands, Amsterdam, i'd like to say hi as a beginning watch enthusiast.
I'm a proud owner of a Frederique Constant, Aerowatch and a couple of Sea-Gulls.
But, i found out that there is more than wearing a nice watch, the complication behind it
is even more interesting! I therefore bought some instruments to demount and
assemble a movement:). And perhaps (hopefully) later on assemble my own watch with different components.
I therefore use the youtube watch repair channel to gain myself the basic information, many thanks for these interesting videos!
Little question to end my introduction though, does anyone know which movement I can
buy to demount and assemble the Rotary AS 1900? In fact, which movement can be compared mechanicly the same
as the AS1900, and doesn't cost a fortune. Cause I will use it as an assemble movement. (by using the AS1900 service video I want
to take the movement apart and assemble it back again to learn how the movement works).
Watch regards!
Jorick
Hello Jorick,
just thought I would mention there is an AS1900 on the bay now but it is going to be about £43.00 plus postage.  May be cheaper than a watch containing that movement though.
Cheers,
Vic
AS1900 is a nice movement but if your just srarting this facinating hobby you really don't need to buy expensive unless money is no object to you a cheaper running movement of the bay will suffice just remember to take a photo at each step of the breakdown and remember to place the parts as you dismantle them in a separate partition in one of those plastic partitioned containers, then you can keep parts that go with each other together. And once you've cleaned your parts just work backwards through your tray and pics. Oh and hello btw have fun.
Mick
Many thanks for the replies, would probably buy it on ebay!
Finally found an active forum with people who are sharing the same interest:)
Welcome Jorick! As our friends above just said, no need to start with an expensive movement. Although it might seem a worn out advise, I would say, start with a simple, big movement like the ETA 6498 which can be had on ebay for about 40. Make sure it works so when you are done, if it still works, you know you are doing fine. Then, you can buy from the same ebay a case and other "periferals" :) and build your own watch with that movement.
Cheers,
Bob
  • Similar Content
    • Hi watchweasol, yes that is a way of doing it I suppose, I have a pair of mainspring hole making pliers on their way off eBay, the ones with the different shaped punches. I may be able to use them to make a hook.
    • Hello everyone, Glad to be here.
    • This is a modern watch, the crown is definitely made from solid 316l steel. You must have heated the crown to some 200C caused the surface colour to change to light yellow. It's similiar to steel tempering. Yes it is the chromium oxide that forms during the heating that gives rise to the colours you see as you know stainless steel contains chromium. The fact the crown is SS lead me to a question, you've never heard of the alum method? Because alum would work perfectly in this case, instead of drilling, which, there is always a risk of damaging the crown, I would just let the crown chilling in some warm alum solution for 1-2 days and the job is done.   Sure can but the thing is the crown is not just mirror finishing, the lock symbol is polish while its background is some sand-blasted finishing so it would be hard to replicate that. You can buff it all shiny but losing the sand-blasted finishing means it won't look exactly like before.   Gasket is always tricky to me. I would try to use some gasket that look closest to the broken one in term of thickness and diameter, and check if the replacement gasket fit with some friction to the case tube. Lastly you can still use alum at this point.
    • No mate. Sorry if that offends you! Also please don’t take threads off-topic. I thank you sir.
