Heavy Duty Lem Back Opener.
My latest acquisition from Fleabay for £41 is an LEM screw case back opener. It was in functional but poor condition when I received it, but after a good clean and minor refurbishing it looks the business. It will fit screw backs up to about 45mm with the standard x6 square notch screw backs. It is built like the proverbial brick sh-- house so should deal with the tightest of backs.
  • 6 months later...
No luck but I found a pricey solution forced on me...I broke my old one! It is unbelievable or maybe my Taekwondo years are paying off, using only my hands - mind me, bare hands -- and really pushing it I broke the metal jaws of a Swiss tool: on one hand the case holder, on the other hand this tool which I broke where the arrow is pointing (clean off the center of the jaw, not the tip, I should have taken a picture):
Not an easy feast mind you! It was solid metal! The watch is still not budging. Some special oil over night then, while making soup in a pressure cooker, put the watch on the lid to "warm" it up, then in the fridge to "cool" it down quick, repeat, still not budging! I'll post a picture later. Finally I broke the tool trying to open it. Damn Seiko screw on back!
New machine, still processing at the post office:
Tool + attachments = $$$$ you don't want to know ( and much less to let my wife find out!) :hot:
Cheers,
Bob
Edited by bobm12
Morning Geo,
I just spotted this on eBay and thought of you;
181617709288
It looks like it's a set of additional inserts or adaptors for your U-boat case opener. Absolutely no use to anyone unless they have the rest of it, which you do.
Just thought you might be interested.
Wow!
Some things are meant, thanks for the heads up Marc, I really do appreciate it.
Now bought and paid for.
If you ever have a watch back that is as tight as vintage rifle barrel to unscrew, just give me a call. :-)
  • 7 months later...
Hi Geo, Nice Buy. You do not see many of these Japanese jobs around. I only know 3 guys with them you are number 4. I have the manual if you require a copy let me know.
Mine is 40 years old in good condition used nearly every day and the steel jaws are still perfect. I have manufactured different lug plates mainly to accommodate TAG cases.
It got beat the other day for the fist time :( a Breitling 13 sided 26mm Quartz on so tight it managed to force the jaws back enough to slip the flats.
Enjoy.
Terry
A warm welcome to the forum Terry and thank you for the comments regarding the LEM case opener.
I had no idea that it was Japanese, I've trawled the net and found nothing about it whatsoever. I would be most obliged if you could furnish me with a copy of the instructions. I'll send you a PM with my address.
This is a great forum with lots if very helpful guys from all sorts of backgrounds, I do hope you post some of the work you get up to and join in with the fun. :)
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
