Following on from my introduction post I would be grateful for some advice in getting this watch back in working order,it belongs to my wife, was borrowed by my daughter who took it locally for a battery replacement , and the rest is now my problem!! please see attached photos
The watch has an ETA 956-032 movement and Id like to know if someone can point me in the right direction for the female part of the split stem inc crown that is/are missing, Im unsure whether the stem and crown are one piece or 2 pieces. the total length of the female part would need to be approx 5.5mm to the outer edge of the stem tube (+ if crown separate)  the spec for the stem is tap 10
There are 2 other issues I would like advice on
1) the dial is mirrored glass bonded to a thin brass plate with locating lugs which press fit into the movement. The inner surface of the case has a machined groove which at the moment the dial sits up against, Surely the groove should have an "O" ring fitted to cushion the glass dial as I cant imagine the watch would be designed otherwise
2) The back is held on by 4 screws ,should there not be a gasket between it and the case ?
If you look on cousins uk you can get the missing stem portion ETA956101964 however I would rather fit a single piece stem to avoid the possibility of losing it again.
They have a decent selection of crowns, you need a waterproof one that takes in the pendant tube.
An O-ring between dial an case is absolutely unusual but
You can get the caseback gasket by size.
thanks jdm, the problem with the one piece stem is that you can fit it but theres no way to remove it once assembled as the pendant tube is attached to the back so theres no access to the button to release the stem
Regarding the dial O ring it may not be normal but surely its needed as direct glass to metal contact isnt the best combination
Right, I didn't noticed that.
I really don't think any gasket goes there. Glass, mother pearl and such delicate dials are directly fitted to metal. Nothing happens because the pressure is uniform and well distributed.
    • The ones I have opened also do not have a pry point , hence the reason for the tool. The watch is clamped in the tool and a blade is screwed into the seam, the blade being chamfered lifts the back then the screw shaft is turned and the back comes off have a look on Ali express for case back removal tools
    • I don't think I need to know more about the question now, so please don't write anything related to the topic. Thank you to everyone who wrote. Have a nice day.
    • It's an exhibition back so no access as you suggest.
    • I have no experience with this watch, but looking at the pictures from the ebay listing linked above, it looks like the outer metal bezel at the back of the watch may not be part of the case proper.  It looks like the watch and strap are sandwiched together, and an inner case may push out of the rear bezel towards the front of the watch.  A case style similar to the Roamer watches where the crystal, movement and caseback pushed out through the back of an outer bezel, only in reverse - this one may push out towards the front.  To test this, you would need to hold the watch, dial down, supporting the dial side of the watch around the edge of the bezel without touching the bezel itself. Then push down carefully on the inner metal ring you can see at the back of the watch. I’m speculating here, proceed at your own risk. Hopefully someone with hands on experience of these watches can chime in! Best Regards, Mark
    • Thanks, Mark. That's the kind of reassurance many of us wanted to hear! Yes, life is unfortunately unpredictable, and it would be a shame if the many dedicated WRT: ers became stranded if, god forbid, something happened to you and WRT stopped working.
