Great watches Seiko lots of bang for the buck, Huge but could you wear it all day in comfort, I have a Caesar which I love but after a day wearing it I have a red mark where the crown digs into my wrist.
I don't have a monster but I've thought about it. Observe the crown is at the 3.45 position so cant see why it would dig into the wrist. Assume it has a 7s movement?
Sent from my SM-T585 using Tapatalk
3 hours ago, Daveb said:
My latest addition, orange monster. you definitely know it's on your arm.
Seems a tad large for your wrist size.
It doesn't dig in at all, but is quite heavy.
Yes it's the good old 7s26, so when it comes to service time maybe I will be confident enough to do it myself.
I do have small wrists and it is large but looks a lot bigger in the photo, maybe it's the angle. I had to get one I've got a thing about orange, not sure how long I will keep it for though.
Same here, I've quenched the thirst with an SKX017. But they aren't easy to find.
    • Hi watchweasol, yes that is a way of doing it I suppose, I have a pair of mainspring hole making pliers on their way off eBay, the ones with the different shaped punches. I may be able to use them to make a hook.
    • Hello everyone, Glad to be here.
    • No mate. Sorry if that offends you! Also please don’t take threads off-topic. I thank you sir.
