Hi guys, recently got a Witschi watch expert in a lot of watchmakers stuff I bought. As I am still in the learning stage I am looking for a manual of the watch expert, maybe someone can share this?
thanks CB, I think the biggest difference is that the early edition does not have the ability for the coaxial measuring. Would be great if I can get a hold of the manual to know how to operate exactly.
Yes it would be nice but it looks like to operation is very much straight forward. The really nice features are the 24 hour & the average mode options.
it says watch expert on the back so it is the first edition, it's from 1997 so pretty old but I am very happy with it. I will take a look at Mark's video and see if I can interpret the readings.
  • 4 weeks later...
For anyone that's curious about what witschi timing machines are like the first link has demonstrations you can download. Seating kinda play with the buttons and see what things are supposed to look like.
Then there's actually four generations of the watch expert. First three generations the case looks identical except color. Enhancements added to each generation improving things. Third generation has a backlit screen which hopefully makes it much easier to see. The second-generation screen is a really shiny and reflects everything like overhead lights. Fourth-generation the machine below is basically an entirely new machine.
So first link demonstrations and the Witschi Training Course Which really is good for anyone with a timing machine.
http://www.witschi.com/en/service/downloads/instruction-document.html
http://www.witschi.com/en/group-of-devices/measurement-of-mechanical-watches/watch-expert/watch-expert.html
  • 4 years later...
36 minutes ago, SUNDANCE said:
Witschi Watch Expert II or some advice on making it display correctly on auto
What kind of display problem are you having?
when I put it in auto mode it says out of range when in manual works fine I do not know if I bumped the settings accidently or need a new brain lol
Witschi timing machines are interesting versus the Chinese. If things are perceived to be out of range the witschi machine will give a variety of error messages and then refused to do anything. If it's a Chinese machine it typically will not give an error and will try to show something whether it's right or not.
Then it be helpful to know which watch are you timing and a picture of the display in manual mode when it's running as you perceive correctly.
In auto mode the machine will attempt to figure out what frequency watch you have. In auto mode it has a limited number of frequencies it will look at basically the standard. If it perceives its outside of that then you get the error message. This is where in manual mode you select like 18,000 it now knows what it's trying to time and it will time it providing its within the range of what it can do. Simplistically it's telling you it's having a problem that needs help which means there's probably some issue with the watch perhaps.
This is where it be nice to have something this machine does not have a oscilloscope. But you can also listen to it and see if it sounds right. Because anything that sounds incorrect might be upsetting the machine anyway.
Then sometimes If things get really bad you can go to rate only it won't display amplitude or beat But usually that solves the problem if things are really having issues and you still want to display something.
Then I'm attaching the PDF of the users manual
witschi watch expert II user manual.pdf
the watch it went goofy on is a Omega 561 19,800 BPM auto should pick it up lol thnx for the technical manual download it helped
