Best Flooring For A Workshop
Mrbeebe2125
This is interesting as I have just started building my new workshop. It would be nice to hear what other say.
Personally I have decided to use vinyl. Something smooth with no indents.
I thought about using laminate flooring and perhaps tiles, but the vinyl flooring is winning by virtue of it's smoothness (I mean the type with no pattern) and the professional stuff as used in hotel bathrooms very hard wearing.
It also needs to be a single colour if possible, easy to spot any part which may fall on the floor, a neutral colour like light grey perhaps.
  • 3 months later...
colours something I'm interested in knowing the answer to! I've dropped parts & been on my hands & knees from time to time. I've often thought red would be good, But is there a winning colour for spotting pesky little wrigglers on?
Regarding colour, my floor covering is light cream and contrasts with most watch parts that have ended up there. I've certainly dropped more than my fair share over the last couple of years and always managed to find them.
I suppose that statement is the kiss of death to my track record!!
Im currently working on the floor that was in my unit when I got it, its not a plain pattern. its black & grey flecks. Thankfully I've only had a couple of peices drop on it, but it was a nightmare finding them!
  • 3 months later...
There was a material I used in my house kitchen and hallways called Interflex...maybe there is a color/combination available for a watchmaker shop.
The advantages I see in it is that this material can be pieced together seamlessly (special glue and applicator), cut to shape, it looks like tiles and has low or no maintenance, keeping its shiny looks. It is warm to the feet (winter in Chicago) and resistant to temperature changes. There were many advantages that I can't really remember when I bought it do remodel my property back then.
Colourwise I would go for whatever contrasts well with the colour of potential missiles that ping out of the movement you are working on.
Also, what about interlocking PVC tiles. Most have a textured pattern so should stop bits rolling away if dropped.
Edited by ro63rto
I have a black plastic(linoleum) floor, if you clean it every day and use indoor shoes its easy to find parts which are usually shiny.
But you need to sweep the floor every day so you find the parts easier
br
emso
p.s: sent from my s****y phone so sorry for typing mistakes :-)
Honestly, my indoor shoes are actually sandals with a rubber type of sole that what I can't find with my eyes or a magnet, I simply walk all over the place and then check the soles. Most of the time the parts I'm looking for are buried in it! Seriously!
As long as you use them in your workshop only then you dont have problems,if you use them outside you bring impurities inside and make the floor dirty and every dust particle will trick you that it is the missing part which you look for in an uniform color floor
br
emso
That's correct, I only use them there. The rubber soles are very, very soft and easily punctured so they effectively catch the parts. Still I have to be careful in case the part in question is not a "durable" one like a screw or some types of small bridges.
Edited by bobm12
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
