Waiting for time to finish the job off - hopefully in the spring because I need a new shed to store the stuff that's currently in there.
Mark, good luck on your new shop completion. Look forward to seeing your new shop in action
I may have a similar need coming in the near future. I was thinking of setting up a large trailer home with workbenches and cabinets next to our home. Its insulated and comes with heat and air conditioning.
Its just a glint in my eye right now so we'll see what happens.
Al T.
Yes - going for white silk.
I put the lighting up and have changed my mind now about the strip lighting. Very flickery and noisy. The flickering will cause migraines - and the noise will drive me nuts. I just took it down for painting and will not be putting it back up.
Got some kitchen units for the base which I will sit on house bricks to bring them up to height. Plywood for the worktops which I will laminate. Lots of work to do, but i'm fired up.
It's great to hear that you are nearing completion Mark. Having just fitted LED lights in my kitchen, I decided to purchased an LED lamp from Cousins; it will be here on Monday and I'll let you know what I think of it.
https://www.cousinsuk.com/product/led-lamp
Just put loads of GU-10 LED's in my kitchen this week. They are brilliant.
Just finished the second coat - going to have to do one half first because of all the stuff. Keeps threatening to rain so I can't put it outside.
I trust there will be more room. Looks good wish I had room to do the same but my garage is separate & it would need a lot of money to rebuild + building regs might be an issue.
Indeed. Found some low energy bulbs online with equivalent of 170w each 35w actual and a daylight tone. Will order 6 of them. Hopeful that will be enough light for the room (aside from the bench lights of course)
The end of a busy weekend. Painted, units constructed and lights fitted.
These three are plenty bright enough. Three more will go on the other side of the workshop.
    • This is indeed a unique site and members including myself genuinely care about it.  All we want is the site to continue.
