Turned out great! That LED light looks really good.  Hopefully someone here in the US can find something like it at a similar price.
Amazing job Mark, real nice working place,...time to stuff the place with watches, tools and the works...no more tidiness!  :D
Cheers,
Bob
Cheers,
Bob
No bob, I plan to keep it tidy.....
... for about five minutes :)
So we've seen your workbench area Mark, what you doing with the remainder of the space in there?
Partially for my desk and computer. The other part is for more benches for my lathe, dirty work (soldering etc.) and equipment. And I have a small annex room for the polishing and ultrasonic machines and storage.
Mark makes a really good point here. I have a really small workshop & contamination after working on my lathe is a real problem. A complete separate section of the workshop is essential. I have to cover my work bench with a dust sheet before the lathe,drilling,filing etc. procedures as that **BLEEP** swarf gets everywhere.
Edited by clockboy
What a cracking job you have done Mark, working should be a pleasure. I would also thank you on behalf of the members for your kind words regarding their input to the forum. :)
Cracking workshop Mark. You have created a really functional work area. Have you ever calculated how much you have spent on your equipment. At a guess I would say you have at least 20k.
Ditto. Well done Mark. As you mentioned in the video, if you want to find something out - look on the web.
Really enjoyed the tour of your workshop Mark, well done, looking great thus far!  Funny you should mention the radio being an important factor in your working day, I suffer from tinnitus, and have recently started to listen to the radio through my iMac which really does help work, and reduce me from hearing the ringing in my ears.
Fantastic video! It's really cool to see the inside of a working shop. I've been working up my nerve to approach a local watchmaker and beg for a tour. This is the next best thing.
All those tools...why isn't there a "drool" emoticon? And there's that Cousin's LED lamp again.
Thanks for posting!
I have no idea to be honest. But I do know it never ends :)
Very true!
I have mild tinnitus, but it seems extremely loud at night sometimes, I found this app for my iPad which just plays for the amount of time you specify a particular sound you choose. It is a real big help and gets me to sleep most of the time.
    • If the watch is new, just return it to the seller for a refund or replacement.
    • Keevo, Welcome to the group ! I'm thinking that you have some damage to the hour, and/ or minute wheel. Possibly just a bent, otherwise damaged, or missing tooth.   Your photo didn't post that I can see. I think you'll have to open it to start really finding the issue. Best, Randy
    • An industrial break cleaner , like Holts does a good job of rinsing off paraffin
    • In cap jewels on several watches I have serviced over the years. I've recently serviced a couple of Longines movements where the cap jewels were colourless. They are a real pain. Without colour they disappear when immersed in any liquid for cleaning 😲 Not necessarily. Cousins do a 10ml bottle for £26 which will last me for years. That's just half the price of a simple Bergeon silicone cushion, so not too expensive 🤣
    • I wanted to post an update as I have two movements running really well now, 230-250 amplitude , 0.5 and under beat error, and +/-8 seconds or so. I removed the hairspring assembly in order to start over and noticed that the terminal curve between the stud and regulator arm was distorted. The stud was lower than it should be. I massaged the curve to look pretty good and reinstalled it. I followed Alex's video advice, best I could with 10x magnification, and with the regulator arm set in the middle of the curve I adjusted the stud so the spring was centered. I then made sure I could move the regulator arm the entire terminal curve without upsetting the coils. I then put it back on the Timegrapher and began closing down the regulator pins until I saw a change in amplitude which means to me that the pins were now pinching the spring. I opened them slightly and it looks good except I have a 0 on dial down, +3 on dial up but -16 on crown down.  I'm a bit stuck on how to adjust out the positional error. I also noticed a drop in amplitude, 180-200 on crown down. In the other video link I posted at about minute 26 if I remember he adjusts out positional error by manipulating  the regulator pin gap. With crown down the hairspring falls away from the pin and the rate slows so he closes the pins a bit to keep them tighter in crown down position. That means the spring is tighter on dial up as well but then he moved the regulator arm to slow the movement.  There must be some Seiko experts here that have some methods for dialing out positional errors.
