The other day I changed a coolant header tank on a Ford Fiesta, the new one came from Ford with a blanking plug in the filler hole,
I was about to throw it away then I thought .....mmm one of my old cameras has a missing lens cap,
so I took it home and washed it..  a perfect fit    :)
Classic old camera I used a 50 all through my college days 1980 to 3 a true work horse liked it so much i upgraded to the 5b in about 86/7 and used it for years  ahhh happy memories.
    • Hi watchweasol, yes that is a way of doing it I suppose, I have a pair of mainspring hole making pliers on their way off eBay, the ones with the different shaped punches. I may be able to use them to make a hook.
    • Hello everyone, Glad to be here.
    • No mate. Sorry if that offends you! Also please don’t take threads off-topic. I thank you sir.
