On 4/6/2017 at 0:06 AM, ricardopalamino said:
Hi Joe , Thanks ,...Yeah , it came out looking pretty good . I just picked up another model that I will be posting soon .
It turns out that the dial side balance pivot is slightly bent and would stop when the dial was up . Fortunately I had another 505 movement ready to go and I switched out the balances and got this puppy running good .     I installed  the balance with the bent pivot into my spare movement and it will run and keep good time if I don't install the cap jewel over the jewel in the shock spring .  I tried to add some end shake in the jewel/spring holder , but no love .
  I could try changing out the shaft with a spare , BUT there is a lot of stuff on the shaft ,....Hairspring , balance wheel with a good integrated coil attached , a teeny weeny wire from the coil that threads through a tube to a contact / jewel plate , a finger block and actuating pin....Sooo , no cap jewel for that guy .... Don't tell anybody .
Hey it cool. I've done that to a watch in my collection. Later on I was able to address the balance staff properly with a donor moevment that appeared. You know how it is: with patience, all things related to parts eventually appear!
J
    • Update: The demagnetization only helped temporarily, maybe it pulled the wheels into a position where they liked each other. I have to adjust the sub second hand as it is a bit angled upwards and catching the minute hand stopping the whole movement but before this happened there were some wild deviations. HWGIKE#58 Alarm clock, cooked in hot cleaning fluid and oiled gently. This is a movement so I count it. 🙂 A while ago it tried to fly away one day, it was on my windows sill, we had strong wind the curtain flew like a flag and doing so encouraged my clock to do the same...  went out and ended up on the roof above the entrance door, its door in pieces but the clock itself suffered no damage otherwise. The original glass was already broken when I received it I still have the bottom part in two pieces. The new "glass" is acrylic. It also had a paper in the back in the case inside but it disintegrated, I still have a little bit of  piece of that too.     HWGIKE#59 Durowe 870 / Times M84 This particular instance is a D870, when I saw its worn out contact pin I thought that it must be a design flaw, and here we go: https://17jewels.info/movements/d/durowe/durowe-870/ An incredible movement again where the balance wheel drives the train and has two magnets one for the balance wheel/coil and one for the pallet. The magnet for the pallet is basically the "draw" one direction. The coil is about 1.8kOhm and one end is in contact with the main plate and the other end is soldered to a contact pin which is insulated by the means of putting it into a jewel and this contact pin is rubbing against a wire getting the energy/impulse as it is passing. Behind the contact pin there is an "impulse jewel" not sure why is it there... the wire seems to hit the impulse jewel first then the contact pin but maybe it is there only for insulation purposes? I was almost certain that the screw holding down the battery - (minus) clamp had no insulation washer.. i only noticed the green stuff around it coming from battery leakage... anyway the + and - had a shortcut which took me a while to realize.. had to fabricate one insulating washer on my own. The jewel settings were dirty but not it is all cleaned and oiled. The contact pin might work for a while but I am sure it has a short life. It is a front loader the whole thing is held together by the case so it is not possible to regulate it without putting it all together and taking the movement out of the case again, very inconvenient. A wonderful movement but not made for eternity only for the consumer market.
