ETA 2824-2 - Cant engage manual wind
Hi all,
I've been labouring over this issue all weekend and just can't fix it. In assembling the keyless works in a ETA 2824-2 (actually a "Chinese clone" - cloud this be the issue??) i cannot get the manual wind to engage.
I have re-assembled the works several times, substituting parts from another 2824 (clone) movement to try to eliminate the faulty part.. But no joy.
When i look carefully at what is going on, the Double Corrector lever is not pushing the Yoke across to the right far enough to engage the clutch wheel to the winding pinion, it's falling short a couple of mill. I can push the clutch over with a screwdriver the rest of the way and then the winding works (until the clutch slips off of the pinion again).
I've had no end of trouble with the keyworks on this movement (stem dislodging the Setting Lever etc etc.. Does anybody have any experience of this problem ? Am i likely to experience these issues due to using a cheap clone ? I've actually just ordered all of the separate (genuine ETA) keyless components from eBay to see if they work when i fit them.. This is bugging me !
Thanks
Darren
15 hours ago, rogart63 said:
Had trouble with a 2632 just about now? Couldn't get it to wind with the crown either? Found that the bridge was worn here? Changed the bridge for a better one and now is working again.
Yeah, don't think its a bridge issue as i can place the clutch where it needs to be manually, just can't get the yoke to do it !
Is it locked up or just don't wind when you turn the crown?
My Eta 2632 has about the same construction as a 2824?
i could wind it with a screwdriver on the barrel but when tried to wind it with the crown it was locked up .
An other old movement an 2532 i have has a broken winding pinion.
Have the right stem?
Not locked up, Roger.. The clutch is just falling short of the pinion, when the keyless work is set to "wind" (so it just spins freely). I just took delivery of every part of the keyless work (including stem) so i'm going to put them all in over the weekend and see what happens.. After that, i'm beaten and i'll put it down to a poor clone..
"to see if" is the right expression.. let us know.
Edited by jdm
CRACKED IT (actually, thanks to Mark's "Servicing 2824" video).. The problem was that i was engaging the spring with setting jumper (thanks, "SirMike) but not (at the other end) with the "Return Bar".. Such a simple fix but had me stumped for days. THANK YOU MARK (and to everybody for your help).. Happy man.. now.. about fitting the balance... !
Edited by DarrenThomson
  • Similar Content
    • I found a Trupoise in a flea market box of tools (🇬🇧car boot). I preferred the ‘8’ style tool until the moment I broke my new Omega rivet. The trupoise holds the arms firmly and I’ve become quite efficient… …and I just resorted to bending a balance cock. I needed a tiny bit less shake and it seemed the least risky of the other options. I held it between a stump and a fat stake while I bent the jewel end with my fingers. Honestly I don’t know how anyone would know by visual inspection.
    • It was about 4 years ago, one was 30, another 35 and 2 others came in joblots that I was after something else. 3 have ruby jewels and one has ceramic bearings.The most I've seen one sell for is £330.  In the uk i still see them sell occasionally for around £70.  I'm not convinced that the Trupoise has low enough friction on the pivots to be as good as a traditional tripod poising tool with unworn ruby jaws.
    • I have a Record 525 which is in a pretty bad way. From what I can see it is based on a cal 650 with an automatic bridge and centre seconds pinion under the rotor retaining stud.  There are additional bearings in the train bridge for the bottom pivots of the automatic works. Of these, on has come out of the bridge completely, one is a bit mangled with an egg shaped pivot hole and one is half in, half out. I've made bearings from scratch on the lathe before, but only for pocket watch pivots (i.e. considerably bigger than these!) and these bearings are either plated or not brass, to match the bride plate, I would guess. I could not find a bridge on eBay so I started digging. I checked new Ranfft site (not help, but the new one seldom is) then the cousins download centre but I could not find a document for a cal 525. I did, however find one for the 650 and, scribbled on the page are the words "= Longines 701". So, obvious next step (or so I thought) would be to check the docs for Longines cal 701 and then see if there is maybe a cal close by, based on that cal with a rotor. I checked, no 701 in the downloads section.  I did find some Longines 701 parts on eBay, which look similar to the 650 (i.e. the train bridge looks to be the same) but I feel I have hit a dead end. I have added some pictures that you may find helpful and I have photographed the entire strip down so I have more, if needed.  I feel I have few options: 1. Close the brewing holes up and reinsert the loose bearings. Close up the pivot hole on the 3rd bearing and hope that does the trick. 2. Make some new bearings (doable but tricky and will look wrong) 3. hold out for a 525 bridge to come up online. I get the feeling this is a rare movement though (all the more a shame it is in such a bad condition) 5. See if there is a Longines equivalent and either use that, or transplant the bearings from that bridge to the Record. Any help identifying the Longines equivalent (if it exists) would be appreciated. Any suggestions on the alternatives I have discussed are also welcome
    • Really you paid that little for a legit Trupoise?
    • Nailed it Andy 👍 It kinda was, but had a happy ending all the same.
