Tell me what you think of this.
oldhippy
15 minutes ago, Folkvisor said:
This is really interesting but way beyond me.
I just test myself by putting everything on the bench, mixing it up a little, and then making myself name all the little rascals and telling myself what they are all for. I figure if I know what they are I should be able to put it all back together. LOL
Dave
That is a good way of going about it, just make sure you don't have anything leftover.:D
When I was a little girl, I took a watch apart, taped every part to a piece of cardboard and wrote the names of each of the parts next to them.  I never put that watch back together... in reality, in my lifetime, I have thoroughly destroyed way more watches than I've ever repaired.
Dave, I think you're a brave man for challenging yourself like that... I'm not there yet. :unsure:
Well, I ripped off a regulating pin trying to carefully remove a hairspring. The hairspring is fine but, of course, the watch doesn't work very well.
I'm not even going to try to put another pin on the lever. Time to buy a whole new balance cock methinks...
Years and years ago, I was a student when our music school class was invited to a rehearsal of Byron Janus playing The Emperor with the Winnipeg Symphony Orchestra. One of the students almost hung over him watching him play. During a short break she asked him, "Maestro Janus, how can you play so fast and play all the right notes?" He answered, "Hell, I don't play all the right notes!"
So, there you go...
This topic is now closed to further replies.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
