Different way of cleaning a clock !!!!
clockboy
Interesting for sure. I've cleaned metal parts by boiling them before, with dishwasher soap in the water, usually when there is a tough residue (paint, glue...) that needs to be removed. It's very effective and is a great way of cleaning parts with lots of nooks and crevices.
That being said, I would be weary of using it for clock or watch parts... I'd be afraid that the heat could affect the parts in some way, especially if different metals are involved (different expansion/contraction rates).
But if it works for this guy, and he has waaaaay more experience than I do, then it must be perfectly fine!
35 minutes ago, clockboy said:
Also it does not look that clean when finished.
That's what I was thinking.
Even before I got my US cleaner and just soaked parts in my clock cleaning solution they came out cleaner than that.
What a nightmare of a video. He broke nearly every rule in the book on taking a clock apart.:mad:
After removing the hands and dial, the first thing is let down all the power in the springs. He decided to remove the pallet cock and pallets first, so why didn’t the train wiz round? Very strange, unless it was the editing in the video, never the less it shows what he did and it is wrong. Removing the pins with not a care in the world (I nearly had a heart attack) great care should be taken and each part removed should be inspected for any wear. Never try to undo nuts with nippers they mark the nuts, use smooth jaw pliers or better still use the correct box spanner, which is what I would use. God knows what marks he made while trying to remove the hammer wire and the attachment, the wrestling he had was manly off camera. We could all see he did nothing with the two barrels, never looked at any of the wheels, pivots never checked for wear. The boiling of the parts, what the hell was he thinking of, there are many types of clock cleaning fluids these days with a good cleaning all parts will come up looking like new, his still looked dirty and it was a bloody eye sore. He should be kept away from any type of clock; the man is a bad advert for the trade. :pulling-hair-out::pulling-hair-out::pulling-hair-out:
Clockboy please don’t frighten me with any more like this. :D
4 minutes ago, clockboy said:
Sorry.  just shows not every vid on YouTube is showing rhe correct methods
There's some real screamers on their of idiots changing batteries using there fingers and metal tweezers. A sure sign they won't last long.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
    • Wie ging die Sache weiter?   please use English for your posts    Tom
