So I was given a Bulova watch from a friend and it needs a battery, the problem is there was no battery in the watch.  It looked like it might of been a 377 and so I tried it but it was slightly too big (battery) and too tall.
The movement says Bulova 7292-  tried searching and couldn't find a tech sheet or really any info.
Should I just use calipers and find something close?
Daniel
Did you try Energizer 392? It might fit. (Alternatively, 364 and 369 are one size below and above respectively). They all have the same electrical specs it is just the size that changes. Good luck, hope this helps.
Robert
Check it out but think that particular watch has a Miyota movement probably 98B-131.  A lot of those Citizen/Miyotas use SR927 which would be a Renata 399 equivalent.
Got most of the beers off your list thanks - most nutritious (:-))
Cheers,
Vic
slight addendum - if it is by any chance a Marine Star it would be a 364 or SR621 SW 1.55v rather than the bog standard Miyota type
 377 being slightly to big & to tall (thick?) leaves 379, 317 or 335 in order of popularity.
Hello Dan,
Had a bit time on my hands and judging by all the many and varied responses you got from me included I think we have successfully managed to cloud the issue.  I found yet another reference that suggests the 394 is the correct battery ! complicating matters further.
Given all that has gone previously,I still think that 98B-131 was correct fot the 7292 and if it is a "Marine Star" then here are two links, one will get the new battery for 5 Bucks and the other is a re setting data sheet for the watch.
Hope this helps and sorry if I have confused the issue.
https://www.bigapplewatch.com/battery.asp?prod=battery&watchnumber=BULOVA%2098b131
http://www.retrevo.com/support/Bulova-98B131-Watches-manual/id/24039dj893/t/2/
Cheers, Vic
Sorry for not responding sooner guys. Been a bit crazy here as I recently lost a friend and we are trying to help his young family.
Hello Dan,
Please accept my condolences and I wish you success in providing aid and comfort at this difficult time.
Regards,
Vic
    • By the way, I opened my watch, looked under a magnifying glass, there is simply no grease, the screws are without traces, the slots are intact.I think it's just a matter of maintenance.there are no rotor marks on the body. And to remove the strap from yours, just press on the 1st side,and slightly move the strap, then on the other side and it will come off.
    • Hi My name is Chris. Just started trying to learn about watch and clock repair as a result of repairing my fathers old 1890s police station clock (about a year ago). The clock was Ok, but having graduated to pocket watches and then wrist watches, despite the really excellent stuff on Youtube, I am struggling a bit.  As a retired engineer, I find the engineering exquisite, but a bit on the fiddly side.  I have done a few practice watches with a little success but failed a few, but have had success with Seiko 7005s, 7009s etc, but have just attempted a citizen 5430.  Nightmare.  My wife thought I had found religion as I spent so much time on my knees with my eyes to the floor looking for springs.  Got through that and found that the balance is shot.  Trying to source one or something that will fit from the citizen range has me totally perplexed.  Tried Ebay, Cousins etc without luck.  Any advice as to alternatives that will fit or alternative sources would be gratefully received.
    • Agreed, this is puzzling. Can you ask questions or inspect the lots before bidding? My Boley & Leinen Reform face plate is dia. 95mm exactly. It's possible that 4 inches is a slightly too large approximation, but why then make the distinction to 3 11/16 for the sake of 8mm? If the larger ones are truly 4" then they will clash with the bed, but then I have no idea which 8mm lathe would take them. All 8mm lathes have spindle height 50mm or less, as far as I know. The spindle height is, as you say, standard 50mm for W.W.
    • I have only been a member for six years & I have found this a very friendly forum although I don’t have anything to do with watches not because I don’t like watches but because I have gout in both hands so my dexterity isn’t very good, I restore torsion clocks & occasionally other antique clocks also at 72 my eyes are not what they used to be, that is why I only post on the clock forum & the lathe forum mostly . As others have said Mark it is much appreciated that  you are willing & able to do this. very many Thanks Dell
    • Ah, this is brilliant, thank you very much!
