Delete account
How does one delete the WRT account?....thanks
You cannot delete an account but we can disable your account - please submit a support ticket to request.
4 hours ago, matabog said:
Now, why would you go and do that?
40 minutes ago, digginstony said:
There's nothing really like WRT on the web. Most sites are "Just look how pretty my watch looks today" why delete your account ?
Sent from my SM-T585 using Tapatalk
Gotta agree with these guys, for what it's worth, I have been a member of several MB's and I would not have stayed at WRT this long, if there wasn't something I could gain from it, even as an amateur repair person, not to mention the diverse personalities and colorful commentary. Your have to admit there is no other site like this and I don't try to curry favor with anyone.
Curry:  to seek to gain favor by flattery or attention
We all get discouraged at sometime or another, when you get stuck trying to do repairs or things in general just don't seem to work no matter what you do. I've wanted to get out of watches altogether a few times but my determination to conquer the seemingly impossible tasks won't let me, maybe it's just me. I do know one thing: you can't be successful at repairs, if you give up. You can PM me with why you want to not be a part of this, maybe I can help change your mind.
Dave
14 minutes ago, matabog said:
Ok, you scared me! :))
But what's the computer resources got with the wrt account? I believe you've been lied to.... by your computer! Kill it! Before Skynet takes control... scarry!
Don't forget to say "Asta La Vista Baby" in a very thick, deep accent
:D
No problemo!
  • Mark locked this topic
This topic is now closed to further replies.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
