Thoughts on a fast platform escapement
oli
Hi all
I am working on clock with a small ABEC/ SMITHS platform escapement.
It had a broken balance staff, which I have now replaced. I also fully stripped the movement, cleaned it, reassembled and lubricated it.
Now the movement seems to run reasonably well in terms of amplitude and beat error, but it is very fast, even with the regulator finger in the beginning of its range (several minutes a day.)
I spent a lot of time observing the escapement, and can confirm that:
- the escapement is not magnetised.
- the hairspring is true is and not fouling with anything
- the hairspring coils looks to be in good shape, with no contact between the coil. It is clean and the coils are not sticking together.
So I am at a loss to see what the issue is!
I noticed that if I open the regulator boot, so that neither the pin nor the boot touch the hairspring at all, then the clock runs about right (still about 10/15 sec fast).
All I can think of is that the balance is fitted with an incorrect hairspring? Is there anything else I should be looking at?
Thank you very much in advance
The hairspring should bounce between the regulator pins in whatever position the regulator is in. clockboy is right, let the hairspring out a little from the end but remember you will need to adjust to make sure it’s in beat. Make sure you use a thin oil on the entire escapement but do not over oil as this can cause problems. The platforms fitted in these movements are not the top end when it comes to quality but I have never had any trouble with them. Looking at the photo of the hairspring and balance the hairspring looks small for the balance.
Thank you gents
I am going to move the pinning point of the stud on the spring, to extent the effective length of the hairspring a little, but I get the feeling it won't be sufficient, if this does not work I really don't know what else to do, and would strongly suspect an incorrect hairspring.
@ Oldhippy, the hairspring does "bounce" as you say and makes contact as it should,  throughout the regulator range when the boot is closed. It is only when I open the boot fully that I get no contact on either side (At the beginning of the range of the regulator) - And the fact that the movement still runs fast despite no contact of the hairspring whatsoever with the regulator pin / boot is puzzling me: it is effectively running with the full length of the hairspring (and should be very slow)
Thank you very much for your advice! I shall report back!
Edited by oli
Well that didn't go well! i removed the stud, but as I straightened the spring it broke near where it was secured by the pin (it was very bent/ damaged). So I am back to square one, as i have pretty much the same length of hairspring as before I started.
i have just bought another identical clock on ebay, so it will be interesting to see what the hairspring is like on this one!
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
