Hello everyone!
Recently found Watchmaker Marks youtube channel and found the videos fascinating. It is hard to comprehend just everything that is happening, underneath a watch dial to keep it displaying the time with great accuracy. Look forward to exploring the forum
Gav
Welcome, Gav!
I have a grandson named Gavin... great name.  Lots of good information and friendly, helpful people here in this forum.  Stroll around a bit and don't be afraid to ask questions!   B)
Shirley
Welcome to this friendly forum. You will find plenty here to amuse you about watches of all sorts from the type of tools that are used how to clean a watch, the names of the parts, we even have a clock section.
    • Hi watchweasol, yes that is a way of doing it I suppose, I have a pair of mainspring hole making pliers on their way off eBay, the ones with the different shaped punches. I may be able to use them to make a hook.
    • Hello everyone, Glad to be here.
    • No mate. Sorry if that offends you! Also please don’t take threads off-topic. I thank you sir.
