Hi Guys,
In my hunt to find new watches to practice on, I was given this watch to work on.
The Brand is Q&Q ... and it looked like a new basic movement for me to service.
Once I opened it up, I was shocked to see "NO 0 Jewels" stamped on the back.
Once I removed the movement and looked at the pivot and pallets ... this is what hit me!
PLASTIC!!
ROFL!  What a piece of junk.
But I thought I'd post it for your amusement :)
Don't wear it if you are cooking up a BBQ - it will end up dripping down your arm :D
Plastic fantastic, I've never seen anything like it in my life. It reminds me of the small plastic gifts you used to get small cars in Corn Flake packets back in the fifties. They came assembled, but would break down into about eight pieces for reassembly.
Ah those were the days.
PS Does anyone remember the baking soda submarine? It was my favourite!
Geo,  What is baking soda?
Re. The plastic watch,  I am amazed that changing a few parts to plastic can have a significant cost saving, obviously it does else they would not have bothered.
Lawson,  If you take it apart and put it back together you will have gained some practice and if it all goes horribly wrong,  no great harm will have been done.   :thumbsu:
Autowind - I'm too scared to unscrew it ... everything is under one single plate.
I think it will fly into a million pieces if I pull to the top plate :P
ps. - I should mail it to Mark to video a service on it ... maw haw haw haw
Edited by Lawson
That's just nasty - What did I do to you?
:startle:
hehe ... you know I luv ya mate :)
Just thought you could use it for a comedy video mate.
I can do my best John Cleese impression with it!
In an odd sort of way - given that modern plastics are very sophisticated these days - I'm surprised that more use of the material isn't made in watches...
Thank you Will, that's an excellent link (and sub-links at the bottom). I was wondering if casting with one of those smooth-on kits will allow to build one! I'm currently preparing to experiment with the plastic gears in the Seiko movements I'm restoring.
    • I’ve been playing with a NH35 movement that which has the classic Etachron regulation system and a few balance assemblies as practice. What I’m trying to do is get comfortable with the effect both the stud and regulator pin positions have on rate and positional error. When I install a new balance assembly I install it with the assembly in place  on the cock and cock is attached to base plate. I use the back of the tweezers to push the stud into place and feel the click. However, I noticed that the angle of the stud can be adjusted and what I also noticed is that some movements have the stud carrier arm bent down a little and that changes the angle of the hairspring leaving the stud. This angle effects how the spring goes through the regulator pins and also the spacing of the coils opposite the stud. What I thought I was supposed to do is set the regulator block in the middle of the curve, open the pins, and use the stud angle to center the spring.  Then the stud is set.  Now on all the new NH movements I have seen the angle of the regulator block is about 60 degrees counter clockwise from full open. I watched a video where the author used the regulator pin adjust to adjust rate and position error. When I close down the pins I do notice that the rate increases but also the amplitude drops, the coil spacing changes and hairspring appears slight straighter between the stud and the regulator block. If I open the pins the amplitude comes back, the spring breathes a bit more between the stud and the regulator block and the rate slows.  So, a long post I know but I would really appreciate any advice on how to correctly adjust the etachron system for rate, amplitude and positional error.
    • Aw come on Andy, it was just a comparison between spending 30 quid and tackling a tricky piece of work. You appeared to be volunteering,  i volunteer for stuff all the time it gets me into all kinds of trouble.
    • It's not really shown here , but the blade flips over, so it faces the other way. The knob and threaded case holder then pushes the caseback seam into the blade. Once the blade starts to penetrate into it, the lever and blade are lifted , which should hopefully pop the back off. A lot of fashion style cases have very tight seams and need a sharp blade to start separating them.  Don't buy the cheaper plastic versions of this tool, the posts with the pins through for blade holder break easily if the apply extra force to blade.
    • You will still be looking for a balance complete I’m afraid, this is the balance staff, balance wheel and hairspring in one package. Hairspring and the balance wheel are matched in the factory. Whilst we can change a balance staff the hairspring and balance wheel stay together.   Tom
    • The hairspring end has come adrift from the small terminal barrel.  I have tried to remove the taper pin to relocate it, but the task is beyond my skill set, eyes, hands and being in my 70s, probably beyond my life expectancy.  It is not too badly mangled on the end.  On the ebay offer, that really is a bit on the rich side.  I'll keep looking, maybe a good hairspring will turn up with a shot balance staff. As for time spent on knees.  I made up one of these from 3M magnetic tape and a piece of wood.  It works well for magnetic parts. Other things I have suffered with.  I found lubricants so very expensive that I bought some very small syringes and tiny needles.  I just decant a drop into my oiling pots when I start a movement and the remainder keeps really well in the syringes. Finally identifying the correct screw for the part led me to make up the board in the final pic.   Thanks for the info. Kind regards   Chris
