Which one would you like and why
oldhippy
Id go for the second of the two good quality french movement in a interesting case, the Angelus is a modern clock produced I would say sometime in the last 30 years and although Angelus being regarded as a good maker it lack's the quality of the second of the two it is definetley not a antique clock.
2nd one because it's cheaper :)  Neither are very old I suspect (they both say "made in"... which to me in a hint). I wouldn't buy either of those.
The first one looks modern, no natural corrosion anywhere.
The second one has 2 different styles of hands, some clearly replaced parts, looks a bit older..,
the Angelus looks like a fairly modern reproduction no discoloration of the enamel dial also the brass shows no sign of tarnishing.The second clock shows lots of age discoloration and the hands on the dial are not a matching pair. But ideally, you need to look in person to see the movement to know for sure.
It would be the second one for me, battle scars and all.  Whether the parts are correct for the case I don't know, but to me it is an old movement, pinned together and has a look of elderly quality.  A bit like yourself OH! :)
PS The pendulum has 3606 lightly scribed onto it which appears to match the number on the movement.  This probably indicates it's original to the clock.
The correct name for these original clocks is French Four Glass Clocks. Most come with a mercury compensated pendulum this means the effect of the weather will not affect the time keeping. Many have visible escapements. They come in various cases from very plain to extremely decretive and can be quite valuable. Most movements are striking on a gong or bell, although I have come across Timepieces.  I have included a photo of a nice decretive one so you can see what I mean. They would have been made from around the 1860 to about 1913 certainly not in or after WW1. Correct about the pendulum it should have the same number as the movement.
The Angelus is a modern clock and it has a bim bam movement or ting tang, two bells and two hammers and has little resemblance to the original apart from the shape of the case, it even has those terrible clips to hold parts on such as the clip holding the bell in place.
It would be the second one for me no hesitation at all.
Thanks to all for taking part.
Late in replying, but I'm please to say I would of gone with the second one too, the screw on hands, nasty C clip and the general 'not old' look of the first one put me off, not to mention its hard to say, but it does look like it has cracks in the glass on the pendulum.
43 minutes ago, clockboy said:
I got it wrong I am was really surprised that the movement with a mercury pendulum has such a basic movement.
Thats why I am a amateur I suppose. B)
They are extremely good movements made with very hard brass and steel.
12 minutes ago, clockboy said:
Agree I have serviced / repaired many of these movements and they are really well made.  I just was expecting something better/unique.
I'll see what I can do the next. I'm always looking for something different but not to difficult to keep the clock section interesting.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
