Hi all Nigel here great to be part of this group and to start exploring the fascinating world of Horology and i look forward to chatting to you all and sharing ideas.
Hi Nigel Welcome on the forum . Yes the horology is a big world but very fascinating . Here  you have many connoisseurs who give excellent advice . So do not hesitate to ask for help .  ;)
Edited by SeikoWatch
Welcome to the forum,  Nigel.
From which part of ireland do you come? Have been to connemara some years ago - beautiful country, friendly people, great pubs, good beer!
    • Hi watchweasol, yes that is a way of doing it I suppose, I have a pair of mainspring hole making pliers on their way off eBay, the ones with the different shaped punches. I may be able to use them to make a hook.
    • Hello everyone, Glad to be here.
    • No mate. Sorry if that offends you! Also please don’t take threads off-topic. I thank you sir.
