Stone clock?
Has anyone here ever made one of these? http://www.woodentimes.com/. There are a couple of places that sell plans.
I was looking at them the other day and later drove past a local granite supplier who has a waterjet cutter that will cut any shape. I've had an idea buzzing round my head since then about making a stone clock... wondering whether it would be possible to make a clock that would happily stay outside all year in british weather... pivots may be a problem, but brass shafts with stone sleeves might work.
Any thoughts?
I had a customer order granite plates from Starrett to use in telescopes as temp stable baseplates.  They have the same expansion and contraction rate as both aluminum and borosilicate glass. So for securing the aluminum truss it was perfect.  I made the worm gear for his clock drive out of aluminum alloy for the same reason.  All this mass made his scope very stable.
All that said you could cut your gears from aluminum and hide that in granite. so it would look like great big granite wheels.
21 hours ago, frenchie said:
Friction might be an issue on all the gears (not the pinions, the teeth). But a fun project nonetheless :)
Yes - will need to find out how good the cut surface finish could be. I had imagined glued in brass bushes for the pivots.
Thanks - this is useful. Never really thought that hard about it before, but CTE is a a good reason for using brass plates with brass wheels. Not sure that aluminium gear teeth would last that long however. Part of my idea was that granite is rock hard and wouldn't wear.
On 4/7/2017 at 1:48 PM, StuartBaker104 said:
Thanks! I had something smaller in mind :wacko:
I imagine so :)
Still, you might be able to make use of ceramic bearings like they do for the wheels. Try a search for ceramic skate bearings, and Silicon-Nitride Ceramic Balls etc.
Granite is not just solid stone, it's mostly chucks of silicates like quartz so it is very hard like glass but all pressed together like a huge block of broken bits.
As a surface it is abrasive. When I tested metrology tools I would test gage blocks and the granite plates for wear.  It tended to be the hardened steel gage blocks that would show wear from being used on the granite plate. Granite plates are slightly porous while being very flat and harder than steel. So the flat gage blocks can be moved around with digging in or sticking. It is a ultra fine abrasive.
You may want the teeth to have a smoother, less abrasive wear surface like steel or a ceramic. The granite would be a great backing to that surface. Think like a dental crown for teeth. I think as gears the granite wheels would eat themselves up.
In France there are a great many abandoned mill stones. Many are dark Alpine Granite. Some are hundreds or thousands of years old. Those might be great for your project.  Possibly even very inexpensive.  Here in the states a great many have been imported to be re-used as mill stones. A water powered grain mill in Waco Texas has two pairs of French stones. The miller says as long as they don't touch the stones last forever.
I wish you great Success!
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
