Do you own a ticking bomb ?
wls1971
Whilst doing a bit of research on anniversary clocks I came across a few intresting articles on a Haller clock that through a combination of bad design and wrong use of plastics can literally self destruct on your mantle piece and can cause injury, they where eventually withdrawn from the market, if you have one call bomb disposal:biggrin:
The danger comes from the fact that the mainspring for this 400 day clock is wound onto nylon spools that over time become brittle and can fail at any time releasing all the energy from a reverse wound spring this as earned them the nick name "The german time Bomb"
http://erkelzaar.tsudao.com/models/ultra/german-tb.htm
http://www.anniversaryclockidentification.com/pages/sh-gbt.pdf
  • 1 year later...
Hi All,
I just came across this thread, did not see this one.....I am ashamed to say that this was ME, this was my first and LAST Haller clock!!
I got this from an auction and when I got it home, I could not wait to try it out to see if it worked.. At the time I was only into the restoration of French slate clocks, so this was a new one for me.
I set it up and tried to wind, but it was fully wound, so started the balls going and it worked. I wanted to see that it worked OK before stripping down to clean it, as it was a tad grubby and I like to tinker... After about twenty minutes it stopped, perhaps it needs a drop of oil I thought,..BIG MISTAKE!!! I started to undo the 4 nuts on the backplate, un-be known to me this also held the mainspring in place. what a stupid setup, no warning not to remove.
Well this is how I gave it the name of The German Time Bomb, because it went BOOOM it exploded very loud, and the plastic mainspring wheel after it shot out and broken into lots of pieces, it embedded in my chest, I also got a nasty cut on my hand, I was very lucky, if that had hit me in the eye, I dread to think what would have happened. The photo doesn't show all the bits of the mainspring, there were lots!!...Lessons were learnt that day.. Strange I read there was another that exploded on someone's mantlepiece about a week later, this was just sitting there and suddenly went, there was glass everywhere from the dome...My clock went in the dustbin never to be seen again.. I remember later I put the dome off mine on ebay and got more for that than I paid for the clock!!
As I said lesson learned!!!!!!
I will stick to my French and carriage clocks, a little safer!!
Len
I have serviced/repaired Haller's in the past but not that particular calibre.However the absolute rule with clocks is ALWAYS remove the power before stripping a clock. The springs on clocks are powerful and if let loose uncontrollably they can not only destroy a movement but cause serious damage to yourself.
Great advice to the newbie..Too late for some..Like myself...lol
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
