Post any stupidly made object here..
I'll start... cheap tire pressure gauge from SE Asia... the Imperial scale is repeated on the four sides of the sticking part, but with the smart variation of being lb. or PSI. Asking for metric would have been too much?
Edited by jdm
    • No mate. Sorry if that offends you! Also please don’t take threads off-topic. I thank you sir.
    • Thanks Mark I have uBlock Origin Lite add-on for my Windows Chrome browser, so I've never seen a single ad on this site ! It also removes all adds from Youtube - I couldn't bear to watch it without uBlock
