Greetings and Salutations!
I'm sure you can get some help here, just look through the sections and post a question. Who knows? If you use the search function, you may find that someone has already discussed your issue!
Have Fun!
Welcome from me as well,
If you need help I am sure that once the problem with your watch is posted some advice will be given, the more info you can give on the problem the easier it is to help and there is a wealth of experience at all levels in the forum.
Cheers,
Vic
    • Hi watchweasol, yes that is a way of doing it I suppose, I have a pair of mainspring hole making pliers on their way off eBay, the ones with the different shaped punches. I may be able to use them to make a hook.
    • Hello everyone, Glad to be here.
    • No mate. Sorry if that offends you! Also please don’t take threads off-topic. I thank you sir.
